Sony Alpha 6000 Shutter Button Replacement
  1. Sony Alpha 6000 Shutter Button Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the camera is turned off by turning the switch to OFF.
  2. Sony Alpha 6000 Shutter Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the camera around to access the battery compartment.
    • Slide the battery compartment lock to the left to unlock it.
  3. Sony Alpha 6000 Shutter Button Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the blue latch that holds the battery in.
  4. Sony Alpha 6000 Shutter Button Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the latch back to release battery.
  5. Sony Alpha 6000 Shutter Button Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The battery can now be taken out of its compartment.
  6. Sony Alpha 6000 Shutter Button Replacement, Back Cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the camera upside down and unscrew these two bottom 6 mm screws located on either side of the body by using the J00 head screw.
  7. Sony Alpha 6000 Shutter Button Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the camera sideways.
    • Open the mini HDMI compartment and locate the two 6 mm screw underneath and another to the right of the compartment.
    • Unscrew using the J00 head screw.
  8. Sony Alpha 6000 Shutter Button Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the two 4 mm screws within the battery compartment and unscrew them using the J00 screw head.
  9. Sony Alpha 6000 Shutter Button Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Bend the camera's screen forward to uncover two 3 mm screws below the eyepiece.
    • Locate them and unscrew them.
  10. Sony Alpha 6000 Shutter Button Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha 6000 Shutter Button Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool around the body of the camera to wedge the back cover off. Start from the bottom next to the battery compartment.
    • If necessary, lightly use your hand to pull the the back cover down to completely remove it.
  11. Sony Alpha 6000 Shutter Button Replacement, Shutter Button: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the back cover is off, locate the flash of the camera and push it forward to open it
  12. Sony Alpha 6000 Shutter Button Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the two 3 mm screws within the flash and unscrew them
  13. Sony Alpha 6000 Shutter Button Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hold the camera from the bottom and using a spudger, go around the top of the camera and separate the top plastic piece from the main body.
  14. Sony Alpha 6000 Shutter Button Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha 6000 Shutter Button Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hold the top of the camera away from the body.
    • Carefully turn it over to uncover the bottom of the shutter button.
  15. Sony Alpha 6000 Shutter Button Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the two screws holding the shutter button and unscrew them.
  16. Sony Alpha 6000 Shutter Button Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the screws are out, use a pair of tweezers to pull out the circular metal piece under the shutter button.
  17. Sony Alpha 6000 Shutter Button Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the top plastic piece back over.
    • Now you will be able to completely remove the camera's shutter button.
Now that the shutter button is removed, you will be able to replace it with a new piece. To reassemble your device, follow these instructions in reverse order.
Fernando Sierra
crwdns2935283:009/30/16crwdne2935283:0
376 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 4-5, Passmore Fall 2016 crwdns2935289:0USF Tampa, Team 4-5, Passmore Fall 2016crwdne2935289:0
USFT-PASSMORE-F16S4G5
Check also https://www.youtube.com/watch?v=y3CCJtD0...
You don't need to remove the back cover (and don't try it because first, you need to remove the top cover...)
Philippe Combronde - crwdns2934203:0crwdne2934203:0
Where can i buy a replacement button?
Simon Lundh - crwdns2934203:0crwdne2934203:0
You can find the flexible cable with the shutter button on aliexpress:
https://www.aliexpress.com/store/product...
Lac Uster -
crwdns2936753:07crwdne2936753:0 43
crwdns2936753:030crwdne2936753:0 155
crwdns2942667:0crwdne2942667:0 17,609
