Sony Alpha 6000 Shutter Button Replacement
    1. Sony Alpha 6000 Shutter Button Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Make sure the camera is turned off by turning the switch to OFF.
    2. Sony Alpha 6000 Shutter Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Flip the camera around to access the battery compartment.
      • Slide the battery compartment lock to the left to unlock it.
    3. Sony Alpha 6000 Shutter Button Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the blue latch that holds the battery in.
    4. Sony Alpha 6000 Shutter Button Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Push the latch back to release battery.
    5. Sony Alpha 6000 Shutter Button Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • The battery can now be taken out of its compartment.
    1. Sony Alpha 6000 Shutter Button Replacement, Back Cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn the camera upside down and unscrew these two bottom 6 mm screws located on either side of the body by using the J00 head screw.
    2. Sony Alpha 6000 Shutter Button Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn the camera sideways.
      • Open the mini HDMI compartment and locate the two 6 mm screw underneath and another to the right of the compartment.
      • Unscrew using the J00 head screw.
    3. Sony Alpha 6000 Shutter Button Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the two 4 mm screws within the battery compartment and unscrew them using the J00 screw head.
    4. Sony Alpha 6000 Shutter Button Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Bend the camera's screen forward to uncover two 3 mm screws below the eyepiece.
      • Locate them and unscrew them.
    5. Sony Alpha 6000 Shutter Button Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha 6000 Shutter Button Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a plastic opening tool around the body of the camera to wedge the back cover off. Start from the bottom next to the battery compartment.
      • If necessary, lightly use your hand to pull the the back cover down to completely remove it.
    1. Sony Alpha 6000 Shutter Button Replacement, Shutter Button: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Once the back cover is off, locate the flash of the camera and push it forward to open it
    2. Sony Alpha 6000 Shutter Button Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the two 3 mm screws within the flash and unscrew them
    3. Sony Alpha 6000 Shutter Button Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Hold the camera from the bottom and using a spudger, go around the top of the camera and separate the top plastic piece from the main body.
    4. Sony Alpha 6000 Shutter Button Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha 6000 Shutter Button Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Hold the top of the camera away from the body.
      • Carefully turn it over to uncover the bottom of the shutter button.
    5. Sony Alpha 6000 Shutter Button Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the two screws holding the shutter button and unscrew them.
    6. Sony Alpha 6000 Shutter Button Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Once the screws are out, use a pair of tweezers to pull out the circular metal piece under the shutter button.
    7. Sony Alpha 6000 Shutter Button Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn the top plastic piece back over.
      • Now you will be able to completely remove the camera's shutter button.
Now that the shutter button is removed, you will be able to replace it with a new piece. To reassemble your device, follow these instructions in reverse order.
Fernando Sierra
crwdns2935283:009/30/16crwdne2935283:0
400 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 4-5, Passmore Fall 2016 crwdns2935289:0USF Tampa, Team 4-5, Passmore Fall 2016crwdne2935289:0
USFT-PASSMORE-F16S4G5
Check also https://www.youtube.com/watch?v=y3CCJtD0...
You don't need to remove the back cover (and don't try it because first, you need to remove the top cover...)
Philippe Combronde - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Where can i buy a replacement button?
Simon Lundh - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
You can find the flexible cable with the shutter button on aliexpress:
https://www.aliexpress.com/store/product...
Lac Uster - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 54
crwdns2936753:030crwdne2936753:0 170
crwdns2942667:0crwdne2942667:0 20,110
