Sony Alpha 5100 LCD Replacement
  1. Sony Alpha 5100 LCD Replacement, LCD: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the power switch on the top of the camera to "off."
  2. Sony Alpha 5100 LCD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the LCD screen so that you have access to the back of the screen. The front of the screen should be facing the direction that the lens is facing.
  3. Sony Alpha 5100 LCD Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha 5100 LCD Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 2mm Phillips #00 screws on the back of the screen.
    • Remove the two 2mm Phillips #00 screws on the top of the LCD screen.
  4. Sony Alpha 5100 LCD Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pry open the back plate off the screen with an iFixit opening tool.
    • If separating the plates is giving you trouble, aim for the notch at the bottom of the plate.
  5. Sony Alpha 5100 LCD Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha 5100 LCD Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully open the back plate of the screen.
Kevin Raggiani
crwdns2935283:010/30/19crwdne2935283:0
444 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S4-G6, Saloman Fall 2019 crwdns2935289:0UMass Dartmouth, Team S4-G6, Saloman Fall 2019crwdne2935289:0
UMASSD-SALOMAN-F19S4G6
Hello, thank you for this but it’s only half the steps, how to remove the LCD and touch screen after step 5? Something else is holding it in place. Can lift the outer edge a little only. Possibly it is glue or tape? My touchscreen is always active and focus rectangle moving around the lower part of screen. Can touch screen and it will go there but soon moves back to lower area.
Thank you.
John Meldrum - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 2,174
