This guide will show how to change a Sony Action Cam HDR-AS15 Circuit Board with efficiency. Reason why you will need a circuit board replacement is because it isn't functioning properly or needs a change. Using this guide will show step by step on how to fully replace the circuit board. Some hazards you should know is, be careful when removing the circuit board because you need remove it safety. Special requirements you need is being careful and patient. For your camera to work properly you will need the circuit board to work. The skills required for this guide aren't major all you need is to understand the procedures. There aren't special skills that you need. First you will take apart the camera case to access the circuit board after removing the battery. The tools you will need is a screwdriver and tweezers to complete the guide. Following these steps will ensure a great repair.
To access the battery, gently pry open the rear cover of the action cam.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using a pair of tweezers, firmly grip the protrusion where the PULL signifies and remove the tray and battery.
Open the bottom tab with your finger or a plastic opening tool.
Pull the tab out, not up, to remove it completely.
Remove the two screws from the device.
Use your fingers to remove the plastic plate.
Separate the outer casing from the electronics by pushing on one of the ports toward the back end of the case. The electronics should slide right out.
Remove the two 6.4 mm screws on the LCD side of the device using a Phillips #00 screwdriver.
Flip the LCD display downward to reveal the circuit board.
