Sony α6000 Motherboard Replacement
  1. Sony α6000 Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony α6000 Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Begin by placing the camera facing upside down.
  2. Sony α6000 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony α6000 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the notched locking bar on the battery compartment from LOCK to OPEN.
  3. Sony α6000 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony α6000 Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the small blue bar horizontally off of the battery.
  4. Sony α6000 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony α6000 Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery.
  5. Sony α6000 Motherboard Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 1.75mm Phillips #00 screw from the left side of the camera.
  6. Sony α6000 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony α6000 Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 1.75mm Phillips #00 screws from inside the battery department.
  7. Sony α6000 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 1.75mm screw using a Phillips #00 head from underneath the flash.
  8. Sony α6000 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the ribbon of the flash from the socket by using a pair of tweezers.
    • The best known method to removing the ribbon is to use a pair of tweezers with a rubber tip. This will help to prevent damage to the ribbon.
  9. Sony α6000 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The top of the camera will be free and can be removed.
    • Set the top of the camera to the side.
  10. Sony α6000 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 1.75mm Phillips #00 screws just below the eye sensor.
  11. Sony α6000 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 1.75mm Phillips #00 screw from underneath the SD card cover.
  12. Sony α6000 Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two 1.75mm Phillips #00 screws from the bottom of the camera.
  13. Sony α6000 Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 1.25mm screw from the right side underneath the battery cover.
  14. Sony α6000 Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 1.75mm Phillips #00 screw just to the right of the eye sensor.
  15. Sony α6000 Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Set the eye sensor aside.
  16. Sony α6000 Motherboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back panel of the camera.
  17. Sony α6000 Motherboard Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 1.25mm Phillips #00 screws near the top of the camera, just to the left of the eye socket.
  18. Sony α6000 Motherboard Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 1.75mm Phillips #00 screws from the bottom of the camera.
  19. Sony α6000 Motherboard Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 1.75mm Phillips #00 screws from the right side of the camera.
  20. Sony α6000 Motherboard Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove one ribbon that is attached to the selector wheel with a pair of tweezers.
  21. Sony α6000 Motherboard Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • lift up the protector plate and remove one ribbon that is attached to the LCD screen with a pair of tweezers.
  22. Sony α6000 Motherboard Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the LCD screen from the back portion of the camera and set it aside.
  23. Sony α6000 Motherboard Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up the black cover to reveal the motherboard and ten ribbons.
    • Use a pair of tweezers to gently pull the ribbon cables out of their sockets on the motherboard.
  24. Sony α6000 Motherboard Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 1.25mm Phillips #00 screws located on the borders of the motherboard.
  25. Sony α6000 Motherboard Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the power supply at the bottom right hand corner with a pair of tweezers.
  26. Sony α6000 Motherboard Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the motherboard up and remove the last ribbon cable with a pair of tweezers.
  27. Sony α6000 Motherboard Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motherboard and set aside.
Rohn Albertson
crwdns2935283:007/14/19crwdne2935283:0
635 crwdns2915208:0crwdne2915208:0
IUPUI, Team S2-G2, Harley Summer 2019 crwdns2935289:0IUPUI, Team S2-G2, Harley Summer 2019crwdne2935289:0
IUPUI-HARLEY-SU19S2G2
crwdns2947412:05crwdne2947412:0
I have been wondering what path I will take when I replace my battery contacts part and this looks like an ideal guide for how I can do it. I wondered why you don’t discharge the capacitor before removing ribbon cables. When I removed the top block off my nex-6 I did discharge the capacitor as what the service manual suggested before I removed the control dial and flash ribbon cables. Before I did it I found a youtube about using wires to the discharge contacts going to a light bulb to safely discharge the capacitor. The service manual suggests using a short jig R:1 k Ω/1 W but since I don’t have access to an electronics store nearby the youtube did the trick trouble free.
georgevp1 - crwdns2934203:0crwdne2934203:0
I was successful with the dissembling the camera and will need to invest in a working logic board and maybe something that is part of the shutter. I was hoping the camera would be an easy fix but sometimes this isn’t this case.
is there a way to fix the hdmi out port without buying a new mother board?
Nicholas Costanza - crwdns2934203:0crwdne2934203:0
Hi this is a really helpful guide thank you but I need to go a bit further to replace the sticky shutter. Do you have a guide for that please
richardmason18 - crwdns2934203:0crwdne2934203:0
It really should be mentioned in step 9 to discharge the flash's capacitor using a resistor. It can be sitting at 200+ volts for long after the camera has been turned off, which is quite dangerous.
junstred - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 118
crwdns2942667:0crwdne2942667:0 5,195
