Sony α6000 Back Case Replacement
  1. Sony α6000 Back Case Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony α6000 Back Case Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Begin by placing the camera facing upside down.
  2. Sony α6000 Back Case Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony α6000 Back Case Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the notched locking bar on the battery compartment from LOCK to OPEN.
  3. Sony α6000 Back Case Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony α6000 Back Case Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the small blue bar horizontally off of the battery.
  4. Sony α6000 Back Case Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony α6000 Back Case Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery.
  5. Sony α6000 Back Case Replacement, Back Case: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Position the camera with the bottom facing upwards and the lens facing away from you.
  6. Sony α6000 Back Case Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the battery is removed, use a Phillips #00 screwdriver to remove the three screws at the bottom of the battery compartment.
  7. Sony α6000 Back Case Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Phillips #00 screwdriver to remove the screws located next to the camera strap.
    • There may be screws on either side by the camera strap mounts. If removing the screw on the left side doesn't sufficiently loosen the case, be sure to check for a screw on the other side before resorting to excessive force.
  8. Sony α6000 Back Case Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony α6000 Back Case Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Position the camera with the battery housing facing upwards.
    • Remove the two screws on the bottom of the camera using the Phillips #00 screwdriver.
  9. Sony α6000 Back Case Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Position the camera with the flash assembly facing upwards.
    • Remove the screw located underneath with a Phillips #00 screwdriver.
  10. Sony α6000 Back Case Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony α6000 Back Case Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull back the LCD screen.
    • Remove the three screws directly underneath using the Phillips #00 screwdriver.
  11. Sony α6000 Back Case Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pop off the top case of the camera using your fingers or a plastic opening tool.
    • If using a plastic opening tool, ensure that the pressure is being applied to the plastic rather than the metal.
  12. Sony α6000 Back Case Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony α6000 Back Case Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Position the camera with the LCD screen facing upwards.
    • Gently remove the back case guiding it around the LCD screen.
Ryan Bilitski
crwdns2935283:010/02/19crwdne2935283:0
220 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team S2-G3, Eggleston Fall 2019 crwdns2935289:0The Citadel Military College of South Carolina, Team S2-G3, Eggleston Fall 2019crwdne2935289:0
CMCSC-EGGLESTON-F19S2G3
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 1,993
