Sonos Roam Battery Replacement
  1. Sonos Roam Battery Replacement, End Caps: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sonos Roam Battery Replacement, End Caps: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sonos Roam Battery Replacement, End Caps: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Power off your Sonos Roam before beginning disassembly.
    • Use the metal spudger to pry the end cap with the buttons.
    • Pry from all sides to loosen the adhesive.
    • Use the iOpener, a blowdryer, or a similar heating device to loosen the adhesive if having difficulty.
  2. Sonos Roam Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Roam Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the device to the other end cap.
    • Use the metal spudger to loosen the adhesive.
  3. Sonos Roam Battery Replacement, Speaker Grille: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Roam Battery Replacement, Speaker Grille: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the device so that the Sonos logo is on the top.
    • Use the Torx T6 screwdriver to remove the two 6 mm screws.
  4. Sonos Roam Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Roam Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the device.
  5. Sonos Roam Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sonos Roam Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sonos Roam Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the device so the Sonos logo is on the top.
    • Use the iFixit opening picks to wedge between the split of the grille and the back of the speaker to pry the grille apart.
  6. Sonos Roam Battery Replacement, Speaker Module: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Roam Battery Replacement, Speaker Module: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the TR10 Torx screwdriver to remove the six 7 mm screws.
  7. Sonos Roam Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sonos Roam Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sonos Roam Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Begin to carefully separate the speaker module from the device.
    • Firmly squeeze the middle of the plug using the tweezers to pull it out of the socket.
    • Separate the speaker module from the device.
  8. Sonos Roam Battery Replacement, Outer Circuit Board: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Roam Battery Replacement, Outer Circuit Board: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the TR10 Torx screwdriver to remove the four 7 mm screws.
  9. Sonos Roam Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sonos Roam Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sonos Roam Battery Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the tweezers to flip the latch holding the large ribbon in place.
    • Grab the large ribbon with the tweezers and pull upwards to remove it.
    • Use the tweezers to flip the latch holding the small ribbon in place.
    • Grab the small ribbon with the tweezers and pull upwards to remove it.
  10. Sonos Roam Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sonos Roam Battery Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sonos Roam Battery Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab the metal piece sticking out of the outer circuit board.
    • Pull upwards to remove the outer circuit board.
  11. Sonos Roam Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Roam Battery Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Soldering Iron is very hot and can cause injury if not used properly.
    • Use a soldering iron to desolder the outer circuit board from the speaker casing.
  12. Sonos Roam Battery Replacement, Battery: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Roam Battery Replacement, Battery: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  13. Sonos Roam Battery Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Roam Battery Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tweezers to firmly squeeze the middle of the plug.
    • Pull the plug out to remove it from its socket.
    • Remove the battery from the device.
  14. Sonos Roam Battery Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sonos Roam Battery Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sonos Roam Battery Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the iFixit opening tool to pry the battery out of its casing.
    • Use the iOpener, blowdryer, or a similar heating device to loosen the adhesive if having difficulty.
  15. Sonos Roam Battery Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery from its casing.
crwdns2935229:014crwdne2935229:0
Lauren Young
crwdns2935283:009/20/23crwdne2935283:0
719 crwdns2915208:0crwdne2915208:0
Utah Tech University, Team 1-2, McMurrin Fall 2023 crwdns2935289:0Utah Tech University, Team 1-2, McMurrin Fall 2023crwdne2935289:0
UTAHTECH-MCMURRIN-F23S1G2
crwdns2935297:013crwdne2935297:0
crwdns2947412:012crwdne2947412:0
Great guide. Do you have information on the battery needed? I dont see one available from Sonos, so I presume a 3rd party is required?
mt - crwdns2934203:0crwdne2934203:0
Mit welchem Kleber befestige ich die Abschlusskappen nach Abschluss des Akkutausch am besten wieder?
DocHofer - crwdns2934203:0crwdne2934203:0
Fantastic instructions, saved my roam from being a brick. iOpener is worth every penny! Not a paid advertisement
msdavis4 - crwdns2934203:0crwdne2934203:0
The teardown was easy with these instructions, as was the re-assembly. I replaced the battery with one from AMAZON (they have a lot of them) but no joy - the problem appears too be with the PC board or defective switch - so I bought a new Sonos ROAM 2. Oh well - everything eventually obsoletes and Sonos offered no solutions out of warrantee. Next stop - rep[lace a 3TB fusion drive on an iMac.
Richard - crwdns2934203:0crwdne2934203:0
Just completed this and speaker back to working - only issue i had was step 11 and the wire became disconnected form the board end, not the case - end. All good though as a resoldered it to the board. Was a little nervous about that as I know some boards can't take the heat from resoldering directly to the board. So far so good - enjoying my Jazz channel right now :)
avro57 - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 50
crwdns2936753:07crwdne2936753:0 248
crwdns2936753:030crwdne2936753:0 1,185
crwdns2942667:0crwdne2942667:0 17,756
