Sonos Playbase Optical Audio Port Replacement
  1. Sonos Playbase Optical Audio Port Replacement, Bottom Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sonos Playbase Optical Audio Port Replacement, Bottom Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sonos Playbase Optical Audio Port Replacement, Bottom Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Pro Tech Toolkit
    $63.71
    • Turn the Playbase upside down so that the "Sonos Playbase" imprint is face up.
    • Remove the bottom panel with an Opening Tool by inserting underneath and prying upwards.
    • Melt the adhesive with an iOpener for ease of opening
    • Use a Metal Spudger if the plastic spudgers do not work.
    • Take care to avoid damaging the plastic or the device if using a metal spudger.
  2. Sonos Playbase Optical Audio Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Playbase Optical Audio Port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Pro Tech Toolkit
    $63.71
    • Remove the fourteen 11mm T-10 screws by turning counter-clockwise.
    • Remove the seven 44mm T-20 screws by turning counter-clockwise.
    • Remove the twenty-two 34mm T-20 screws by turning counter-clockwise.
    • Record where each screw belongs for easier reassembly.
  3. Sonos Playbase Optical Audio Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Playbase Optical Audio Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Pro Tech Toolkit
    $63.71
    • Remove the metal plate with a Opening Tool by inserting underneath and prying upwards.
    • Use a metal spudger if plastic openers do not work.
  4. Sonos Playbase Optical Audio Port Replacement, Optical Audio Port: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Playbase Optical Audio Port Replacement, Optical Audio Port: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the optical audio port from the main circuit board by pinching the white clip and pulling upward.
  5. Sonos Playbase Optical Audio Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Playbase Optical Audio Port Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three 38mm T-55 screws preventing you from removing the Optical Audio Port screws by turning them counterclockwise.
  6. Sonos Playbase Optical Audio Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Playbase Optical Audio Port Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Pro Tech Toolkit
    $63.71
    • Remove the two 18mm T-10 screws holding the Ethernet Port in place by turning them counterclockwise.
  7. Sonos Playbase Optical Audio Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Playbase Optical Audio Port Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the Optical Audio Port from the housing by pinching the sides and pulling outward.
James Andrews
crwdns2935283:010/08/18crwdne2935283:0
421 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S17-G2, White Fall 2018 crwdns2935289:0Cal Poly, Team S17-G2, White Fall 2018crwdne2935289:0
CPSU-WHITE-F18S17G2
Thank you for this guide, but any idea where to purchase a replacement optical audio port from?
donovanclarkson - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,597
