This guide shows how to replace the Optical Audio Port from the Sonos Playbase, which supplies the audio input to the Playbase.
crwdns2935267:0crwdne2935267:0Pro Tech Toolkit$74.95
Turn the Playbase upside down so that the "Sonos Playbase" imprint is face up.
Remove the bottom panel with an Opening Tool by inserting underneath and prying upwards.
Remove the metal plate with a Opening Tool by inserting underneath and prying upwards.
Unplug the optical audio port from the main circuit board by pinching the white clip and pulling upward.
Remove the three 38mm T-55 screws preventing you from removing the Optical Audio Port screws by turning them counterclockwise.
Remove the two 18mm T-10 screws holding the Ethernet Port in place by turning them counterclockwise.
Remove the Optical Audio Port from the housing by pinching the sides and pulling outward.
Thank you for this guide, but any idea where to purchase a replacement optical audio port from?
