Caution: Unplug the Sonos Playbase before starting the disassembly to avoid electrocuting yourself.
Replacement of a main speaker requires iFixit prying tools and screwdrivers. Optionally, a heat source helps to more easily remove adhesive while opening up your device.
crwdns2935267:0crwdne2935267:0Pro Tech Toolkit$74.95
Turn the Playbase upside down so that the "Sonos Playbase" imprint is face up.
Remove the bottom panel with an Opening Tool by inserting underneath and prying upwards.
Remove the metal plate with a Opening Tool by inserting underneath and prying upwards.
Disconnect the main speaker array from the main board, by pinching and and pulling the tab out.
Remove the side speakers from the green printed circuit board (PCB) running along the top of the main speaker array by pinching and pulling out the connector.
Remove the two 16mm T-20 screws located on both sides of the main speaker array by turning counter-clockwise.
Remove the main speaker array by gripping it on both sides and pulling it out.
Prop the removed main speaker array up on top of the main circuit board.
