Sonos Playbase Ethernet Port Replacement
  1. Sonos Playbase Ethernet Port Replacement, Bottom Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sonos Playbase Ethernet Port Replacement, Bottom Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sonos Playbase Ethernet Port Replacement, Bottom Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Pro Tech Toolkit
    $74.95
    • Turn the Playbase upside down so that the "Sonos Playbase" imprint is face up.
    • Remove the bottom panel with an Opening Tool by inserting underneath and prying upwards.
    • Melt the adhesive with an iOpener for ease of opening
    • Use a Metal Spudger if the plastic spudgers do not work.
    • Take care to avoid damaging the plastic or the device if using a metal spudger.
    what good is this without a link to where to buy the part you are replacing?
    Rob Wright - crwdns2934203:0crwdne2934203:0
  2. Sonos Playbase Ethernet Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Playbase Ethernet Port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Pro Tech Toolkit
    $74.95
    • Remove the fourteen 11mm T-10 screws by turning counter-clockwise.
    • Remove the seven 44mm T-20 screws by turning counter-clockwise.
    • Remove the twenty-two 34mm T-20 screws by turning counter-clockwise.
    • Record where each screw belongs for easier reassembly.
  3. Sonos Playbase Ethernet Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Playbase Ethernet Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Pro Tech Toolkit
    $74.95
    • Remove the metal plate with a Opening Tool by inserting underneath and prying upwards.
    • Use a metal spudger if plastic openers do not work.
  4. Sonos Playbase Ethernet Port Replacement, Ethernet Port: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Playbase Ethernet Port Replacement, Ethernet Port: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the Ethernet Port from the main circuit board by pinching the white clip and pulling upward.
  5. Sonos Playbase Ethernet Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Playbase Ethernet Port Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Pro Tech Toolkit
    $74.95
    • Remove the two 18 mm T-10 screws holding the Ethernet Port in place by turning them counterclockwise.
  6. Sonos Playbase Ethernet Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Playbase Ethernet Port Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the Ethernet Port from the housing by pinching from both sides and pulling it out.
James Andrews
crwdns2935283:010/08/18crwdne2935283:0
421 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S17-G2, White Fall 2018 crwdns2935289:0Cal Poly, Team S17-G2, White Fall 2018crwdne2935289:0
CPSU-WHITE-F18S17G2
I actually have a broken ethernet port on a playbase. Do you have any idea where I can buy a replacement port?
Thanks,
D
david paler - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,660
