Sonos Playbase A Speaker from the Main Array Replacement
  1. Sonos Playbase A Speaker from the Main Array Replacement, Bottom Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sonos Playbase A Speaker from the Main Array Replacement, Bottom Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sonos Playbase A Speaker from the Main Array Replacement, Bottom Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Pro Tech Toolkit
    $63.71
    • Turn the Playbase upside down so that the "Sonos Playbase" imprint is face up.
    • Remove the bottom panel with an Opening Tool by inserting underneath and prying upwards.
    • Melt the adhesive with an iOpener for ease of opening
    • Use a Metal Spudger if the plastic spudgers do not work.
    • Take care to avoid damaging the plastic or the device if using a metal spudger.
  2. Sonos Playbase A Speaker from the Main Array Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Playbase A Speaker from the Main Array Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Pro Tech Toolkit
    $63.71
    • Remove the fourteen 11mm T-10 screws by turning counter-clockwise.
    • Remove the seven 44mm T-20 screws by turning counter-clockwise.
    • Remove the twenty-two 34mm T-20 screws by turning counter-clockwise.
    • Record where each screw belongs for easier reassembly.
  3. Sonos Playbase A Speaker from the Main Array Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Playbase A Speaker from the Main Array Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Pro Tech Toolkit
    $63.71
    • Remove the metal plate with a Opening Tool by inserting underneath and prying upwards.
    • Use a metal spudger if plastic openers do not work.
  4. Sonos Playbase A Speaker from the Main Array Replacement, Main Speaker Array: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Playbase A Speaker from the Main Array Replacement, Main Speaker Array: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  5. Sonos Playbase A Speaker from the Main Array Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Playbase A Speaker from the Main Array Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the side speakers from the green printed circuit board (PCB) running along the top of the main speaker array by pinching and pulling out the connector.
    • See Recognizing & Disconnecting Cable Connectors for more information.
  6. Sonos Playbase A Speaker from the Main Array Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sonos Playbase A Speaker from the Main Array Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sonos Playbase A Speaker from the Main Array Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Pro Tech Toolkit
    $63.71
    • Remove the two 16mm T-20 screws located on both sides of the main speaker array by turning counter-clockwise.
  7. Sonos Playbase A Speaker from the Main Array Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the main speaker array by gripping it on both sides and pulling it out.
    • The array may require a significant amount of force to remove.
    • Use prying tools as necessary to remove the main speaker array if you are unsuccessful using your hands.
    • Do not to yank the array out too suddenly or too far as this may damage the device.
  8. Sonos Playbase A Speaker from the Main Array Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Prop the removed main speaker array up on top of the main circuit board.
  9. Sonos Playbase A Speaker from the Main Array Replacement, Speaker from the Main Array: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Playbase A Speaker from the Main Array Replacement, Speaker from the Main Array: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Pro Tech Toolkit
    $63.71
    • Remove the four 11mm T-10 screws from the individual speaker that needs replacement, by turning the screws counterclockwise.
  10. Sonos Playbase A Speaker from the Main Array Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the damaged speaker from the array socket, by grasping the speaker with one hand, the array with your other and pulling outward.
  11. Sonos Playbase A Speaker from the Main Array Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Playbase A Speaker from the Main Array Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
George Slivka
crwdns2935283:010/08/18crwdne2935283:0
339 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S17-G2, White Fall 2018 crwdns2935289:0Cal Poly, Team S17-G2, White Fall 2018crwdne2935289:0
CPSU-WHITE-F18S17G2
crwdns2936753:030crwdne2936753:0 37
crwdns2942667:0crwdne2942667:0 3,004
