Sonos Play 5 Mid- Range Speakers Replacement
  1. Sonos Play 5 Mid- Range Speakers Replacement, Front Panel Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect any power to the speaker and wait a few minutes for the capacitors to fully discharge.
    • Flip the speaker upside down.
    • There may be a rubber foot covering the bottom screws (not included in picture). Remove this by pulling up from one of the corners using a spudger.
    By the time you actually reached the motherboard the capacitors will already be discharged sufficiently to a safe level, so just go ahead there's no need to wait in this step.
    That said, be careful once you have the motherboard out and decide to test it on your table. The two large capacitors are directly behind the full bridge rectifier that's connected to the mains, so without load they carry the peak voltage. In Europe with 230V that means 325V, in 110V countries that means 156V (see https://en.wikipedia.org/wiki/Alternatin... for more information about RMS and peak voltages).
    Erik Mouw - crwdns2934203:0crwdne2934203:0
  2. Sonos Play 5 Mid- Range Speakers Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Play 5 Mid- Range Speakers Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove eight 10mm Phillips #2 screws
    • Remove the bottom panel by pulling upwards.
    • Be very gentle with the ends of the three antennas. They are very fragile.
    NB: in the photograph, two antennas of the three soldered on the antenna PCBs are broken: You can see one standing upside down towards the center-right of the photograph
    Toni - crwdns2934203:0crwdne2934203:0
    On my model, only 6 of the 8 screws hold the bottom panel. Looking at the picture above, where the screws are circles, the bottom row of 5 screws, the second and fourth screw are threaded for nuts, as opposed to the other six, which are threaded for plastics. These two screws can be removed once the bottom panel has been removed.
    Like the previous poster said: in this step it is sufficient to remove the second and fourth screw cause these hold the front panel. Removing the front panel takes a bit of force and it is better to have the fragile WiFi antennas protected by the bottom panel.
    The remaining six screws can be removed just before step 13 (which also misses a step, see my comments over there).
  3. Sonos Play 5 Mid- Range Speakers Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sonos Play 5 Mid- Range Speakers Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sonos Play 5 Mid- Range Speakers Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the device so that the grille is facing up.
    • Locate the line on the right side of the speaker where the grill and the plastic meet, and place your plastic opening tool in the gap.
    • Run the spudger along the gap, loosening the grille from the plastic. Repeat this process on the left side as well.
    • Gently pull up on the grille, removing it from the front panel.
    might be worth mentioning there are two strips of industrial velcro running along near the top and bottom that simply have to be pulled apart
    Adam Tibbalds - crwdns2934203:0crwdne2934203:0
    Run the plastic opening tool under the grille to remove to pull the velcro apart. In that way you avoid bending the grille. Be careful with the speaker cones, though.
  4. Sonos Play 5 Mid- Range Speakers Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six 8mm Phillips #2 screws.
    • Remove the two 10mm Phillips #2 screws.
    In my unit the top two screws marked in red had a rubber plug in the hole as well. I had to remove them by sticking a knife in and carefully pulling them out.
    I had the same issue but no problem getting them out.
    clarkal2000 - crwdns2934203:0crwdne2934203:0
    I pulled them out using the corkscrew method: I drove a screw about 10mm deep into the rubber plug, then pulled up the screw. This method created way less damage than other methods i have tried.
  5. Sonos Play 5 Mid- Range Speakers Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Play 5 Mid- Range Speakers Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the line on the right side where the front panel and back panel meet. Place a plastic opening tool in the gap, and run it along the gap. Repeat this on the left side.
    • Use the opening tool to lift the front plate. If a plastic tool is not providing enough leverage, use a metal opening tool.
    • Gently pull up on the face plate to ensure it has been detached from the enclosure.
    • When pulling on the face plate be cautious because it is still connected by wires on the back of the plate.
  6. Sonos Play 5 Mid- Range Speakers Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sonos Play 5 Mid- Range Speakers Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sonos Play 5 Mid- Range Speakers Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift up the front panel, forming a 90 degree angle with the back panel. Locate the locate ten pin connector shown. This is the wire that connects the front panel to back panel.
    • Press down on the small tab located on the connector. With the tab firmly pressed down, pull the connector out from its socket.
    • The faceplate assembly is now fully detached from the rest of the speaker.
    my unit didn’t have the tab in the middle of the connector. It simply had to be prised apart (I used a plastic spudger to separate the two parts of the connector) and then reconnected carefully (I used the plastic spudger again between the pcb and the case to support the pcb as it was flexing)
    My unit has a white gasket between the front and back panel. It was stuck to the front panel when I opened the unit. When rebuilding the unit it was easier to remove the gasket and put it in the small ridge of the back panel.
  7. Sonos Play 5 Mid- Range Speakers Replacement, Mid- Range Speakers: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Play 5 Mid- Range Speakers Replacement, Mid- Range Speakers: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove four 9.5mm Phillips #2 screws.
  8. Sonos Play 5 Mid- Range Speakers Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  9. Sonos Play 5 Mid- Range Speakers Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Play 5 Mid- Range Speakers Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the wires connected to the left speaker.
  10. Sonos Play 5 Mid- Range Speakers Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the left speaker up and away from the front panel.
  11. Sonos Play 5 Mid- Range Speakers Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Play 5 Mid- Range Speakers Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the wires from the plastic clips on the bottom of the front panel.
  12. Sonos Play 5 Mid- Range Speakers Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  13. Sonos Play 5 Mid- Range Speakers Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the plastic speaker cover by lifting up and away.
  14. Sonos Play 5 Mid- Range Speakers Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  15. Sonos Play 5 Mid- Range Speakers Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the right mid-range speaker buy pulling up and away from the front panel.
Warren Girouard
crwdns2935283:002/20/17crwdne2935283:0
309 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S3-G6, Sullivan Spring 2017 crwdns2935289:0USF Tampa, Team S3-G6, Sullivan Spring 2017crwdne2935289:0
USFT-SULLIVAN-S17S3G6
crwdns2935297:018crwdne2935297:0
Thanks for posting this howto on the SonosPlay5.
I have a unit with a broken midrange speaker that needs replacing - do you have any idea where I might purchase one of these please?
Gerry - crwdns2934203:0crwdne2934203:0
FYI, Sonos has a known manufacturing problem with the right midwoofer.
If you hear a distortion like crackling sound from the speaker and the right mid woofer / right mid driver / right mid range speaker feels and sounds different than the left when pushing it in, the easy fix is to just disable it. Press it down along the edge until the rubber edge releases and cut/rip out one of the two silver wires at the bottom.
You will lose a bit of the stereo perspective, but the speaker will sound a million times better already.
https://www.reddit.com/r/sonos/comments/...
"There’s glue that holds the magnet to the speaker/cone.  A half of the glue somehow cracked, releasing one side of the speaker to move about 1-2mm away from the magnet.  This causes the cone to move at a very slight angle, which causes the spring in the middle to rub against the magnet.  That rubbing is the distortion I hear."
Steffen Poulsen - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 18
crwdns2936753:07crwdne2936753:0 32
crwdns2936753:030crwdne2936753:0 64
crwdns2942667:0crwdne2942667:0 5,416
