The wireless communication card receives sound through and internet connection. It is connected to three antenna throughout the speaker, which you will need to unplug from the card. This will need to be replaced if you are unable to wirelessly connect to the speaker.
Insert a spudger along the edge of the screen and gently use it to pull the screen away from the casing. Slide the spudger along the length of the grill to detach all the clips holding it in place.
Gently pull the screen away from the body of the speaker, revealing the tweeter and two mid-range drivers behind it.
Unscrew eight 1.5 inch Phillips #2 screws attaching the front speaker panel to the box.
Unscrew the single 1 inch Phillips #2 screw located on the left side of the panel. This may be hidden beneath the warranty void sticker that you'll want to remove.
Unscrew the single 3/4 inch Phillips #2 screw, which is the last thing holding the front panel to the casing.
Disconnect the front panel from the motherboard by gently reaching in and pushing the tab underneath the wire connector and pulling towards you.
Gently remove the wireless card located at the bottom of the front speaker panel by pulling up and out with your index finger and thumb.
You must first loosen the Phillips #1 screws holding the plastic brackets that keep the Wi-Fi card in place.
On the Sonos Play 3 I opened, the Wi-Fi card lied flat below the plastic clips. Between the card and the clips, there were 2 rectangular foam pads glued to the Wi-Fi card.
Disconnect the motherboard from the power supply board by gently reaching in and pushing the tab underneath the wire connector and pulling towards you.
Disconnect the motherboard from the volume button board by gently grabbing the connector and pulling it towards you.
Using a Phillips #2 screwdriver, remove the 4 screws securing the two plastic panels down.
Remove the two plastic panels on either side of the device that hold the motherboard and power supply board in place.
Using a Phillips screwdriver, unscrew the two screws in the back of the device that hold the motherboard in place.
Gently remove the motherboard from the Sonos device by sliding it straight back towards you.
Using a Phillips screwdriver, unscrew the two screws securing the communication card to the motherboard.
Disconnect the wire connector clips from the communication card by just using your index finger and thumb.
Remove the communication card by grabbing it with your index finger and thumb and pulling it to the right and up.
Do you have a recommendation for a replacement wireless card? If so where can I purchase it?
Maybe it's too late...I have fund this card, which works perfectly on my play:3
Atheros AR5BXB112 AR9380 card Dual-Band 802.11N PCI-E 450M link for Mac Pro wifi card PPD-AR5BXB112
Is this the name for the card, could you please send a link?
This post really helped me reviving my Play:3 that suddenly stopped connecting to WIFI after more than 10 years of constant use. Just search on Becco's description and you will receive a 10 USD replacement piece installed within half an hour, instead of buying a new appliance for 40-times that amount. Always prefer mending over buying ;-)
