A tweeter creates a crisp and accurate high-frequency sound. If the device tweeter is not working, the tweeter may be damaged and may need to be replaced. This guide will demonstrate how to replace the tweeter.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove the rubber footing from the bottom of the device. Pry it up from one end using one of the plastic opening tools.
Once you pry open one end, use precision tweezers to remove rubber footing.
Using a metal spudger, pry open a corner of the adhesive tape.
Use precision tweezers to remove the adhesive tape.
Remove the four 10 mm Torx security #10 screws that hold the base together.
Remove the base by lifting it vertically away from the bulk of the device.
The metal lip doesn’t hold down the metal screen. It’s just a connection/conductor between the inside of the metal screen and the shell against which the motherboard is screwed.
Remove the 10 mm Torx security #10 screw that holds down the exterior screen.
Using precision tweezers, remove the metal bracket.
Remove the exterior screen by lifting it away from the bulk of the device.
Remove the four 9 mm Torx Security #9 head screws. There are two on each side.
Using a plastic opening tool, pry open the top cap containing the power and volume button.
Vertically remove the top cap.
Easily done- fortunately mine didn't snap…
Mi bocina Play1 se conecta a internet pero no se escucha. En el app se ve que está reproduciendo. Si subo o bajo el volumen en la bocina se mueve en el app.
Using a plastic opening tool, pry open the circuit flap.
Once flap is loosened, use your hand to remove the circuit wire.
Using a plastic opening tool, remove the grey tape from both sides of the device.
Remove the six 9 mm Torx #9 screws.
Using a plastic opening tool, detach the rear housing cover from the housing.
Using tweezers, grip the connector fixed to the motherboard's audio cable.
While pulling on the connector, detach the cable by pressing the connectors release.
Using your fingers, grip the connector fixed to the motherboards power cable and detach it.
You will now be able to remove the rear housing cover.
Remove the two 9mm Torx #9 screws fastening the power cable to the housing.
Remove the power cable.
Please add info how and where to connect the wifi antennas on motherboard again
This is very helpful but I managed to remove the speaker easily without removing the power cable to the motherboard, the power cable to the housing or doing anything to the WiFi connectors.
Using a metal spudger, press the release located in the center of the connector .
While pressing the release pull on the connector detaching it from the speaker.
Do this for both connections.
Using the Torx T20 bit remove the four 13 mm screws fastening the speaker to the housing.
Remove the speaker by lifting it up towards the top of the housing and out at an angle.
how do you replace the screw with the magnet nearby???
Does anyone know where to get a replacement speaker?
On the front seal of the speaker driver there is some ID, and there are some lots of pre-owned drivers by that id on AliExpress. They are super expensive though, so it may be easier to get an old full size power speaker from Technics or other and upscale your SONOS by wiring it to the large speaker (there are two channels: one for low/mid frequencies and another for high freq).
Hallo zusammen,
wo gibt’s nen Ersatzwoofer? Ich finde nix.
Using a metal spudger, press down on the clips that lock the input wires to the amplifier.
Once unlocked, pull back on the wires to remove them.
Using a screwdriver, remove the four 10 mm Torx Security #10 screws.
Using your fingers, remove the tweeter from the front of the housing.
Can anybody recommend a source for a replacement tweeter speaker with comparable specs? Unless I missed something, this article doesn't address that, and that's kind of an important piece of the puzzle.
You can get them from Aliexpress for about 10€.
How do I look for the speaker replacement, what characteristics should I indicate because I can't find it, greetings
