Sonos One Mid-Woofer Diaphragm Repair/ Replacement
  1. Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Protective Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Protective Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Protective Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect all power cords.
    • Remove the rubber foot and plastic screw guard on the bottom of the device using a plastic opening tool.
    • Note: the rubber foot and plastic screw guard can be removed as one piece to make reassembly easier
  2. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 10mm Torx T10 screws from the bottom of the speaker.
    More specifics on the four 10mm Torx T10 screws at the bottom, step 2.
    ex: M3
    Thanks
    J Pappas - crwdns2934203:0crwdne2934203:0
  3. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the bottom cover by squeezing the protective cover slightly while pushing up with your fingers.
  4. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The protective cover clip is very thin and deforms easily.
    • Remove the single 8mm Torx T10 screw and protective cover clip.
  5. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the protective cover upwards to remove.
  6. Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Control Panel & Microphone: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Control Panel & Microphone: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Control Panel & Microphone: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pointed end of a spudger to remove the covers that hide the screws.
    • Remove the four 9mm Torx T8 screws from around the perimeter of the control panel.
  7. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the front of the unit facing you, lift the control panel up using your thumbs.
    • There's a ribbon cable attaching the control panel to the speaker so work slowly.
  8. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to flip up the retaining flap on the control panel ribbon cable ZIF socket.
    • Pull the control panel ribbon cable out of its socket.
  9. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the control panel away from the speaker to separate.
  10. Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Power Adapter Receptacle: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Power Adapter Receptacle: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Power Adapter Receptacle: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the six 9mm Torx T8 screws from the motherboard panel.
  11. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a plastic opening tool, separate the motherboard from the speaker.
  12. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using your thumb, disconnect the speaker cable from the motherboard.
  13. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the power adapter plug from the motherboard using your thumb.
  14. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the pointed end of the spudger, disconnect the red, green, and yellow cables connecting the WiFi transmitter/receiver.
    These terminals were covered with a big glob of wax on my motherboard, so I managed to remove the woofer without detaching the motherboard from the speaker housing. So, this step is optional, and really isn’t necessary.
    Steve Davies - crwdns2934203:0crwdne2934203:0
    The red and green need to be swapped around when reassembling it. Don't go off the picture above.
    avalanchenut - crwdns2934203:0crwdne2934203:0
  15. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the motherboard panel from the speaker housing.
  16. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The woofer is highly magnetic, making removal of the metal screws sometimes difficult.
    • Remove the two 9mm Torx T8 screws from the power adapter plug.
    • Remove the power adapter receptacle from its housing slot.
    Brilliant, incredibly helpful. Somehow the adapter had come out of its slot. All working now. Thanks!
    Jolyon - crwdns2934203:0crwdne2934203:0
  17. Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Tweeter Diaphragm: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Tweeter Diaphragm: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Tweeter Diaphragm: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the woofer cables.
    • If removing the tabs is difficult, the flat end of the spudger may be used to depress the middle tab and then the tab may be pulled to disconnect.
  18. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the cables from the tweeter.
    This step is unnecessary unless you intend to remove the tweeter.
  19. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 10mm Torx T10 screws from the tweeter.
    • Remove the tweeter from the speaker housing.
    Likewise, this step is also unnecessary if you just want to remove the woofer.
  20. Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Woofer Diaphragm: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Woofer Diaphragm: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Woofer Diaphragm: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 10mm Torx T10 screws from the woofer.
  21. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The woofer is snuggly fit into the frame socket, some careful manipulation is required to remove the woofer from the housing.
    • Remove the woofer from the speaker housing.
Marcus Glowa
crwdns2935283:002/14/18crwdne2935283:0
1,046 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S2-G1, Nance Spring 2018 crwdns2935289:0USF Tampa, Team S2-G1, Nance Spring 2018crwdne2935289:0
USFT-NANCE-S18S2G1
crwdns2935297:011crwdne2935297:0
crwdns2947412:05crwdne2947412:0
Any suggestion on where to buy these woofers (in Europe/Belgium)?
KimVM - crwdns2934203:0crwdne2934203:0
@mglowa Any idea where to buy a replacement woofer pictured above? Or what to look for, an equivalent perhaps?
Bryan Martinez - crwdns2934203:0crwdne2934203:0
This is the link to the replacement woofer that I used to repair my Sonos One in August 2024: https://www.aliexpress.com/item/10050071...
robotedward - crwdns2934203:0crwdne2934203:0
"SOTAMIA 1Pcs 3.5 Inch Midrange Woofer Speaker 4 Ohm 35W Bass Loudspeaker Aluminum Basin Hifi Music Sound Speaker Audio For SONOS"
56mm high,
75mm distance between adjacent screw holes
105mm diagonal distance between non-adjacent screw holes
97mm width of outer casing
Great guide - replaced the subwoofer using the part above. A few things to note:
Step 13: my unit didn't have an power adapter plug; wires soldered onto board
Step 14:my unit had hardened glue spread on the yellow/red/green cables making removal impossible.
There was no need to remove the tweeter to replace the woofer (steps 18/19).
markrwhite - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 65
crwdns2936753:030crwdne2936753:0 184
crwdns2942667:0crwdne2942667:0 7,387
