This guide is for the replacement of the control panel and microphones for the Sonos One.
Disconnect all power cords.
Remove the rubber foot and plastic screw guard on the bottom of the device using a plastic opening tool.
Note: the rubber foot and plastic screw guard can be removed as one piece to make reassembly easier
Remove the four 10mm Torx T10 screws from the bottom of the speaker.
Remove the bottom cover by squeezing the protective cover slightly while pushing up with your fingers.
Remove the single 8mm Torx T10 screw and protective cover clip.
Slide the protective cover upwards to remove.
Remove the four 9mm Torx T8 screws from around the perimeter of the control panel.
With the front of the unit facing you, lift the control panel up using your thumbs.
Use a spudger to flip up the retaining flap on the control panel ribbon cable ZIF socket.
Pull the control panel ribbon cable out of its socket.
Pull the control panel away from the speaker to separate.
where can I buy a replacement control panel?
