Do you need to replace any of the parts on your Sonos Era 100? Get started by following this guide!
Gently pull off the rubber foot on the the bottom of the speaker.
Remove the five 11 mm Torx T20 screws that secure the bottom plate.
Carefully lift off the bottom plate.
Carefully disconnect the ribbon cable connected underneath the bottom panel.
To detach the back panel, gently push it in a downward motion.
Use tweezers to disconnect the USB-C PCB from the back panel.
Remove the 8 mm and 11 mm T10 Torx screws securing the speaker grille.
Using a halberd spudger, carefully remove the foam tape. Do this by keeping tension on the foam shown in the images and slicing underneath the tape.
Pull the speaker grille off.
Remove all four T10 Torx screws securing the touch bar assembly.
Use an opening tool to release all four white retaining clips.
Lift the touch bar assembly perpendicular to the unit, with care not to strain the connected ribbon cable.
Lift the black ZIF locking flap that secures the touch bar assembly ribbon cable.
Disconnect the ribbon cable.
Remove the touch bar assembly.
