There are two boards for the device, a green top level and a blue lower level. This guide will show the steps to replace the bottom motherboard.
Metal spudgers and similar pry tools can puncture an unprotected battery, potentially causing a fire. When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
Start by using a spudger or plastic opening tool to remove the bottom cover.
Once enough of the glue is removed, peel the cover off by hand,
Remove the four 7.5mm length Philips head screws under the rubber cover.
Use a nylon spudger to unsnap the bottom from the sides.
Pry until the remaining three points are unsnapped.
Once unsnapped, lift the cover.
Remove the connection for the front buttons to fully remove the cover.
Use a plastic opening tool or spudger to remove the adhesive covering the the WIFI connectors.
Gently pull the wires at the connection point to disconnect them from the motherboard.
Remove the two pieces of glue holding the WIFI card in place.
Scrape the glued pad underneath the WIFI card to seperate the card from the board.
Push apart the two clips holding the WIFI card in the connection.
Pull the WIFI card out of the connection.
Remove the 7mm length Phillips screw holding the board in place.
Flip the board over to access the Molex Cable.
Disconnect the Molex Cable from the top motherboard.
Remove foam protective insulator from the bottom board.
Picture shows the side of the device.
Remove the 7mm length Phillips screw from the power supply motherboard.
Remove the adhesive backed rear label by using a spudger.
Remove the two 8mm length screws as shown.
Pull the power supply out of the back of the device.
Were to order a power suply from the Sonos connect??
rickjonkman @ Hotmail.com
thnx!!
Does anyone please know what the 4 coloured power wires in the Molex are, in terms of 12v, A rating and + or - ? Many thanks.
values are printed on the PCB: -
Red: 3.3v+
Black 3.3v GND
Yellow 14.8v+
Brown 14.8v GND
Andy -
Remove the two 7.5mm length screws on the top of the board.
Remove the other two 8mm length screws on the back of the device. You might have already removed the screws for the power supply, and that's OK!
Slide the board out from the plastic casing.
crwdns2935229:08crwdne2935229:0
I have bad audio on one channel, who supplies parts for this equipment?
Careful as the rubber bottom rips extremely easily. Be very patient.
marcos_peixoto1 - crwdns2934203:0crwdne2934203:0
