Solve stuck focus of AF-S VR Zoom-Nikkor ED 70-200mm f/2.8G IF
  1. Solve stuck focus of AF-S VR Zoom-Nikkor ED 70-200mm f/2.8G IF, Solve stuck focus of AF-S VR Zoom-Nikkor ED 70-200mm f/2.8G IF: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The lens. Focusing mechanism traps in close-up end, worsens over time.
  2. Solve stuck focus of AF-S VR Zoom-Nikkor ED 70-200mm f/2.8G IF, Separate front and rear group: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Solve stuck focus of AF-S VR Zoom-Nikkor ED 70-200mm f/2.8G IF, Separate front and rear group: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Solve stuck focus of AF-S VR Zoom-Nikkor ED 70-200mm f/2.8G IF, Separate front and rear group: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • First, you better download the "AF-S VR Zoom-Nikkor ED 70-200mm f/2.8G IF REPAIR MANUAL". (The attatchment)
    • Remove Tripod mount (The one can be removed with only hands)
    • Remove tripod mount base by remove four screws.
    • short
    • long
    • Unscrew switch board and disconnect all three FPC's
    • Remove tripod ring, by removing three hidden screws. check the Repair Manual
    • Remove eleven screws and separate rear group. There is an empty hole.
  3. Solve stuck focus of AF-S VR Zoom-Nikkor ED 70-200mm f/2.8G IF, Remove 4th Lens Group: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Solve stuck focus of AF-S VR Zoom-Nikkor ED 70-200mm f/2.8G IF, Remove 4th Lens Group: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take the front group. remove zoom rubber ring.
    • Peel the tape, and keep if you don't have a replacement.
    • Remove two screws.
    • Remove three screws and remove "4th Lens Group"
  4. Solve stuck focus of AF-S VR Zoom-Nikkor ED 70-200mm f/2.8G IF, Remove Zoom Fixed Ring: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Solve stuck focus of AF-S VR Zoom-Nikkor ED 70-200mm f/2.8G IF, Remove Zoom Fixed Ring: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Solve stuck focus of AF-S VR Zoom-Nikkor ED 70-200mm f/2.8G IF, Remove Zoom Fixed Ring: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew three outer screws and remove Aperture Blade Unit
    • Do NOT manipulate the Aperture calibration screw! (RED mark)
    • Do NOT manipulate the whatever calibration screw! (YELLOW mark)
    • Remove eight black screws and lift "Zoom Fixed Ring" and "MF Ring"
  5. Solve stuck focus of AF-S VR Zoom-Nikkor ED 70-200mm f/2.8G IF, Reposition the PCB: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Solve stuck focus of AF-S VR Zoom-Nikkor ED 70-200mm f/2.8G IF, Reposition the PCB: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Solve stuck focus of AF-S VR Zoom-Nikkor ED 70-200mm f/2.8G IF, Reposition the PCB: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Here is the ISSUE. internal focus ring has contact with Distance readout PCB. The PCB is mounted by double sided tape. This is a design flaw. double sided tape drifts over time, and let the PCB slip out.
  6. Solve stuck focus of AF-S VR Zoom-Nikkor ED 70-200mm f/2.8G IF: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Solve stuck focus of AF-S VR Zoom-Nikkor ED 70-200mm f/2.8G IF: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Solve stuck focus of AF-S VR Zoom-Nikkor ED 70-200mm f/2.8G IF: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • More detail. The infinity end is glued using some better glue(dark material), while the close end is NOT.
    • The fix is
    • Mark or remember the position BEFORE removing two screws and contact brush! but relax, this part is not extremely precise.
    • Lift the PCB. Cleanup double sided tape. Glue the PCB back firmly against the inner edge.
    • Use proper glue, like "high viscous super glue" or "2-part epoxy resin". Do NOT use low viscous glue, it will mess up and contaminate the contacts.
    • Now put it back, following these instructions in reverse order.
    • Screw tighten torque list.
    • Internal M1.6 screws: 0.12N.m.
    • Tripod mount M2.0 screws: 0.2N.m.
    • 2 screws on switch panel: 0.06~0.08N.m (watch out the plastic is very fragile)
Be patient and Good Luck!!!
crwdns2935229:08crwdne2935229:0
crwdns2935103:0crwdne2935103:0
Terrance
crwdns2935283:011/17/09crwdne2935283:0
6,698 crwdns2915208:0crwdne2915208:0
crwdns2935297:018crwdne2935297:0
crwdns2947412:013crwdne2947412:0
Does this fault affect manual focus also ?
Thanks
Arnold Livingston - crwdns2934203:0crwdne2934203:0
It does. And might be worse, because MF sometimes goes faster than AF, then stuck deeper…
Terrance -
Hi Terrance,
So is your lens good til now after this fix? By the way, what type of glue specifically did you use?
t2psalm - crwdns2934203:0crwdne2934203:0
Good as brand new :D. I used “super glue“ and learned the lesson. Luckily the mess is not very bad, cleaned that up and the great lens is happy again.
Terrance -
Will whis work even if my focus ring is stiff (but moves and “jumps”) AF works finw
philippscaglia - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 86
crwdns2942667:0crwdne2942667:0 13,296
