It is a very common issue the AF-S VR Zoom-Nikkor ED 70-200mm f/2.8G IF focus ring stuck at close end. This will show Ifixers how to fix this.
The lens. Focusing mechanism traps in close-up end, worsens over time.
First, you better download the "AF-S VR Zoom-Nikkor ED 70-200mm f/2.8G IF REPAIR MANUAL". (The attatchment)
Remove Tripod mount (The one can be removed with only hands)
Remove tripod mount base by remove four screws.
short
long
Unscrew switch board and disconnect all three FPC's
Remove tripod ring, by removing three hidden screws. check the Repair Manual
Remove eleven screws and separate rear group. There is an empty hole.
Take the front group. remove zoom rubber ring.
Peel the tape, and keep if you don't have a replacement.
Remove two screws.
Remove three screws and remove "4th Lens Group"
Unscrew three outer screws and remove Aperture Blade Unit
Remove eight black screws and lift "Zoom Fixed Ring" and "MF Ring"
Here is the ISSUE. internal focus ring has contact with Distance readout PCB. The PCB is mounted by double sided tape. This is a design flaw. double sided tape drifts over time, and let the PCB slip out.
More detail. The infinity end is glued using some better glue(dark material), while the close end is NOT.
The fix is
Mark or remember the position BEFORE removing two screws and contact brush! but relax, this part is not extremely precise.
Lift the PCB. Cleanup double sided tape. Glue the PCB back firmly against the inner edge.
Now put it back, following these instructions in reverse order.
Internal M1.6 screws: 0.12N.m.
Tripod mount M2.0 screws: 0.2N.m.
2 screws on switch panel: 0.06~0.08N.m (watch out the plastic is very fragile)
Be patient and Good Luck!!!
crwdns2935229:09crwdne2935229:0
crwdns2935103:0crwdne2935103:0
crwdns2947412:013crwdne2947412:0
Does this fault affect manual focus also ?
Thanks
It does. And might be worse, because MF sometimes goes faster than AF, then stuck deeper…
Terrance -
Hi Terrance,
So is your lens good til now after this fix? By the way, what type of glue specifically did you use?
Good as brand new :D. I used “super glue“ and learned the lesson. Luckily the mess is not very bad, cleaned that up and the great lens is happy again.
Terrance -
Will whis work even if my focus ring is stiff (but moves and “jumps”) AF works finw
