Solio CLASSIC2 Electric Wire Replacement
  1. Solio CLASSIC2 Electric Wire Replacement, Disconnecting the Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn off the device by pressing on the clear power button behind the device.
    • To make sure that it is off, make sure the button is not flashing green.
  2. Solio CLASSIC2 Electric Wire Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #1 screwdriver, remove the 2mm screw located on the bottom of the device, near the hinge.
  3. Solio CLASSIC2 Electric Wire Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Solio CLASSIC2 Electric Wire Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Solio CLASSIC2 Electric Wire Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the plastic opening tools, gently pry open the side of the large panel.
    • Keeping the tool in, slowly slide the tool along the side of the panel.
  4. Solio CLASSIC2 Electric Wire Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Solio CLASSIC2 Electric Wire Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the device 180 degrees.
    • Make sure the opening on other side of the device does not snap closed.
    • Gently slide the plastic opening tool along the side of the panel.
  5. Solio CLASSIC2 Electric Wire Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Solio CLASSIC2 Electric Wire Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Do not fully pull apart the back panel from the device. Doing so can rip the two red and blue wires attached to the panel.
    • Using both hands, slowly pull apart the back panel from the rest of the device.
    • Gently flip the back panel open so the circuit board faces up and the two panels are side by side.
  6. Solio CLASSIC2 Electric Wire Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Solio CLASSIC2 Electric Wire Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Softly pinch the red and blue wires close to the white connector.
    • To pull the wires out, wiggle them back and forth until the connector is fully out.
  7. Solio CLASSIC2 Electric Wire Replacement, Circuit Board: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the three 2mm screws holding the circuit board down using a Phillips #1 screwdriver.
  8. Solio CLASSIC2 Electric Wire Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the white USB port cover on the side of the device is pulled out or you won't be able to lift the circuit board.
    • Gently lift the circuit board out of the device using tweezers.
  9. Solio CLASSIC2 Electric Wire Replacement, Electric Wire: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Solio CLASSIC2 Electric Wire Replacement, Electric Wire: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Soldering can melt key components and cause harm to both the user and the device. Read soldering guide before attempting.
    • Using a solder iron with a fine tip, slowly solder off the broken wire from the first connection point.
    • Repeat for other connection point of wire.
Kelly Perkins
crwdns2935283:010/20/13crwdne2935283:0
110 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-28, Amido Fall 2013 crwdns2935289:0Cal Poly, Team 4-28, Amido Fall 2013crwdne2935289:0
CPSU-AMIDO-F13S4G28
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 406
