Open the solar panel of the Solio Bolt. Using a philips screwdriver, remove the screw.
Use a plastic spudger to pry apart the case.
Use a philips screwdriver to remove the three screws securing the battery cradle to the device case.
Move the battery slightly, the motherboard can now be lifted from the device case.
On the underside of the motherboard, remove the battery lead from its connecting terminal.
