Sol Republic Punk Preparing a new battery for Replacement
  1. Sol Republic Punk Preparing a new battery for Replacement, Preparing a new battery for: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sol Republic Punk Preparing a new battery for Replacement, Preparing a new battery for: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sol Republic Punk Preparing a new battery for Replacement, Preparing a new battery for: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Here is the original battery for the Sol Punk. The battery is a 18490 Li_ion 5.18Wh 1400mAh 3.7V
    • The battery control board is connected to the battery via two nickel strips. The Blue arrow shows the negative (-) and the Red arrow the positive (+) connection
    • First thing to do is to desolder those connections.
  2. Sol Republic Punk Preparing a new battery for Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sol Republic Punk Preparing a new battery for Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sol Republic Punk Preparing a new battery for Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Desoldering thos strips is easy enough and one can see they are strictly just bend over to form a solder tab.
    • Do the same for the other tab
    • Both contacts have been desolder and battery control board is now off the battery
  3. Sol Republic Punk Preparing a new battery for Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sol Republic Punk Preparing a new battery for Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sol Republic Punk Preparing a new battery for Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Since the 18490 battery seems to be scarce, I opted for the 18500 model. It has identical electrical specs then the 18490 but is readily available.
    • 18490 length is 48.9 mm and the diameter is 18.04 mm
    • The 18500 is 48.9mm in length
  4. Sol Republic Punk Preparing a new battery for Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sol Republic Punk Preparing a new battery for Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sol Republic Punk Preparing a new battery for Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • but it is 18.10 mm in diameter. The difference will not interfere in the Sol Punk. There is room to accommodate that size
    • The nickel strips used on the old battery are ~3 mm in width.
    • The only strips available at this time are 4 mm strips
  5. Sol Republic Punk Preparing a new battery for Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sol Republic Punk Preparing a new battery for Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sol Republic Punk Preparing a new battery for Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Checking to see if the 4mm strip will fit. There is enough room on the solder pads of the battery control board, to accommodate that size strip.
    • Clean the contact side of the battery in preparation for the weld of the strip
    • and clean the strip itself as well
  6. Sol Republic Punk Preparing a new battery for Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sol Republic Punk Preparing a new battery for Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sol Republic Punk Preparing a new battery for Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Here is the spot welder being used and it's settings are indicated by the blue LED's
    • Lay teh nickel strip straight on the battery contact and use the spot welder according to its instructions. This one does not have a trigger and will weld when it senses contact with both post.
    • Nickel strip solidly attached. The miss on the top is related to not wearing eyeglass when needed :-)
  7. Sol Republic Punk Preparing a new battery for Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sol Republic Punk Preparing a new battery for Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sol Republic Punk Preparing a new battery for Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Bottom or Negative Strip welded to battery. Use the battery control board to ensure the direction of the Top or Positive Strip.
    • Spot weld the Top or Positive strip the same way as prior done with the negative. Place the strip at a 180 degree from the negative
    • Now bend the Bottom or Negative strip up while having it tight to the body of the battery. Use something like a rubber band, or zip tie etc to ensure it is close to the body.
  8. Sol Republic Punk Preparing a new battery for Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sol Republic Punk Preparing a new battery for Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sol Republic Punk Preparing a new battery for Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the battery controller on the top and measure the Negative strip. Bend it and cut it so it covers the solder pad. Do the same for the Positive strip
    • Then solder both tabs to the battery control board in conventional manner.
    • After soldering clean the flux with a cotton tip applicator and some isopropyl alcohol
  9. Sol Republic Punk Preparing a new battery for Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Here is the new battery ready for installation
oldturkey03
crwdns2935283:009/29/10crwdne2935283:0
829,780 crwdns2915208:0crwdne2915208:0
crwdns2935297:0122crwdne2935297:0
Global Fixers crwdns2935289:0Global Fixerscrwdne2935289:0
Community
crwdns2931471:052crwdne2931471:0
crwdns2935297:0419crwdne2935297:0
crwdns2942667:0crwdne2942667:0 350
