crwdns2959928:0crwdne2959928:0 ↓The SodaStream Source is battery operated. But If you are experiencing trouble with your device, and you have replaced the battery, it could be the microchip needs to be replaced. This guide will assist you in removing the carbonation block to access the microchip and replace it.
Spudger4.9
Remove the soda bottle and the CO₂ canister from the machine.
crwdns2935267:0crwdne2935267:0Phillips #1 Screwdriver$8.99
Remove the four 17.8 mm screws from the bottom metal base using a Phillips #1 screwdriver.
Pull the outer cover away from the front of the device.
Remove the two 18.2 mm screws from the bottom of the front cover using a Phillips #1 screwdriver.
crwdns2935267:0crwdne2935267:0Jimmy$7.95
Firmly pull the front cover off.
Remove the 9.1 mm screw from the microchip.
Wedge the plastic spudger between the microchip and the glue dot until the glue pops off.
crwdns2935267:0crwdne2935267:0Spudger$2.99
Use the spudger to lift the edge of the wire and pull the wire out of the microchip.
Great information, but is there someone out there offering this repair as a service, I’m not motivated enough to do this myself and happy to pay someone to do it for me
matteo barnett - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Where can you buy the microchip please?
Jill - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Where can you purchase a replacement microchip from?
David Grosz - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Where can I find the reassemble source at
mcphersonp411 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
