SodaStream Source Loader Tab Replacement
  1. SodaStream Source Loader Tab Replacement, SodaStream Source External Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SodaStream Source Loader Tab Replacement, SodaStream Source External Disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SodaStream Source Loader Tab Replacement, SodaStream Source External Disassembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the soda bottle and the CO₂ canister from the machine.
  2. SodaStream Source Loader Tab Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SodaStream Source Loader Tab Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Phillips #1 Screwdriver
    $8.99
  3. SodaStream Source Loader Tab Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SodaStream Source Loader Tab Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the outer cover away from the front of the device.
  4. SodaStream Source Loader Tab Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    $8.99
  5. SodaStream Source Loader Tab Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SodaStream Source Loader Tab Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Jimmy
    $7.95
    • Firmly pull the front cover off.
    • This piece is difficult to remove and requires force. It may help to use a wide, thin object to pry it off (like a Jimmy).
  6. SodaStream Source Loader Tab Replacement, SodaStream Source  Internal Disassembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SodaStream Source Loader Tab Replacement, SodaStream Source  Internal Disassembly: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SodaStream Source Loader Tab Replacement, SodaStream Source  Internal Disassembly: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the brass bar, located in the top of the device, out of the carbonating block.
    • You can use the end of your screwdriver to push this piece out.
  7. SodaStream Source Loader Tab Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SodaStream Source Loader Tab Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SodaStream Source Loader Tab Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the yellow battery cover up and away to remove it from the device.
  8. SodaStream Source Loader Tab Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SodaStream Source Loader Tab Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unhook the bottom piece of the plastic arm on each side of the device.
  9. SodaStream Source Loader Tab Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SodaStream Source Loader Tab Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the top of the plastic arm with the spudger and remove it on both sides.
  10. SodaStream Source Loader Tab Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SodaStream Source Loader Tab Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the plastic piece, located near the front of the carbonating block, from both sides of the device using a plastic opening tool or nylon spudger.
  11. SodaStream Source Loader Tab Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SodaStream Source Loader Tab Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the plastic oval and the spring within it.
  12. SodaStream Source Loader Tab Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SodaStream Source Loader Tab Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the loader tab cover down and away from the rest of the carbonating block.
  13. SodaStream Source Loader Tab Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 17.9 mm screws located on the right side.
    • These screws may be difficult to access.
  14. SodaStream Source Loader Tab Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SodaStream Source Loader Tab Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unhook the four clips on the top of the carbonating block and remove the plastic cover.
  15. SodaStream Source Loader Tab Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SodaStream Source Loader Tab Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SodaStream Source Loader Tab Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the clips located on both sides with the plastic spudger. Slide the front cover off.
  16. SodaStream Source Loader Tab Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SodaStream Source Loader Tab Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unhook the silver spring arms on both sides of the device by pushing down.
  17. SodaStream Source Loader Tab Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grip the right and left sides of the device and pull it into two identical halves.
    • Once these two pieces are apart, all remaining internal components will fall out of the device.
  18. SodaStream Source Loader Tab Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SodaStream Source Loader Tab Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SodaStream Source Loader Tab Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the foam pad up and remove it from the front side of the carbonation component.
  19. SodaStream Source Loader Tab Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six 17.7 mm screws from the underside of the loader tab piece.
  20. SodaStream Source Loader Tab Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SodaStream Source Loader Tab Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SodaStream Source Loader Tab Replacement: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the loader tab out of the nozzle.
  21. SodaStream Source Loader Tab Replacement, Loader Tab: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SodaStream Source Loader Tab Replacement, Loader Tab: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SodaStream Source Loader Tab Replacement, Loader Tab: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the small inner plastic circle out of the large plastic loader tab piece.
crwdns2935229:08crwdne2935229:0
Angela Mossgrove
crwdns2935283:002/20/17crwdne2935283:0
1 123 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G4, Leahy Spring 2017 crwdns2935289:0USF Tampa, Team S1-G4, Leahy Spring 2017crwdne2935289:0
USFT-LEAHY-S17S1G4
crwdns2935297:041crwdne2935297:0
Thank you SO much for this! I was having a lot of trouble with this thing not releasing the bottle, so I disassembled it all and put it back together and now it works a treat! Not sure what was going on but I am so excited. You weren’t kidding at the end about it all falling apart… took ages to work out how it all went back together, but now I understand it and I have a working SodaStream. 5*!
Amanda L - crwdns2934203:0crwdne2934203:0
Do you know where the tiny magnet goes? It fell out on the table as I was disassembling.
cheryl meeks - crwdns2934203:0crwdne2934203:0
I think it has something to do with the microchip for the LED’s. Can’t figure out how else the light would light. I haven’t taken it apart far enough to find the magnet. Hope this helps you.
Paul Bibeau -
You can see the magnet in step 18, the first picture. Its right below where a screw used to be.
Tom Green -
I placed sodastream on side and removed top half. I could then see where parts needed to be after they “fell out” for reassembly. More pictures of those steps would be helpful. Thank
crwdns2936753:07crwdne2936753:0 41
crwdns2936753:030crwdne2936753:0 184
crwdns2942667:0crwdne2942667:0 25,798
