SodaStream Source Loader Tab Replacement
crwdns2869540:0crwdne2869540:0: 3万
4
52
254
30,145
crwdns2955950:0crwdne2955950:0: 70
crwdns2960004:064crwdne2960004:0, crwdns2960008:06crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 8
crwdns2959974:08crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 2
crwdns2959982:02crwdne2959982:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:045crwdne2931287:0 - crwdns2931289:01crwdne2931289:0
The SodaStream Source creates soda when the loader tab is engaged. Pressing on this tab initiates carbonation and flavor infusion. This tab may become damaged through use and can be replaced through the steps given in this guide. The tab is located within the carbonating block and has its own cover. Replacement of the loader tab requires both external and internal disassembly of the device. This guide shows the steps to access this internal component.
    1. SodaStream Source Loader Tab Replacement, SodaStream Source External Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SodaStream Source Loader Tab Replacement, SodaStream Source External Disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SodaStream Source Loader Tab Replacement, SodaStream Source External Disassembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the soda bottle and the CO₂ canister from the machine.
    2. SodaStream Source Loader Tab Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SodaStream Source Loader Tab Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      Phillips #1 Screwdriver
      $8.99
    3. SodaStream Source Loader Tab Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SodaStream Source Loader Tab Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull the outer cover away from the front of the device.
    4. SodaStream Source Loader Tab Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      $8.99
    5. SodaStream Source Loader Tab Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SodaStream Source Loader Tab Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      Jimmy
      $7.95
      • Firmly pull the front cover off.
      • This piece is difficult to remove and requires force. It may help to use a wide, thin object to pry it off (like a Jimmy).
    1. SodaStream Source Loader Tab Replacement, SodaStream Source  Internal Disassembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SodaStream Source Loader Tab Replacement, SodaStream Source  Internal Disassembly: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SodaStream Source Loader Tab Replacement, SodaStream Source  Internal Disassembly: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Push the brass bar, located in the top of the device, out of the carbonating block.
      • You can use the end of your screwdriver to push this piece out.
    2. SodaStream Source Loader Tab Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SodaStream Source Loader Tab Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SodaStream Source Loader Tab Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Slide the yellow battery cover up and away to remove it from the device.
    3. SodaStream Source Loader Tab Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SodaStream Source Loader Tab Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unhook the bottom piece of the plastic arm on each side of the device.
    4. SodaStream Source Loader Tab Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SodaStream Source Loader Tab Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift the top of the plastic arm with the spudger and remove it on both sides.
    5. SodaStream Source Loader Tab Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SodaStream Source Loader Tab Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the plastic piece, located near the front of the carbonating block, from both sides of the device using a plastic opening tool or nylon spudger.
    6. SodaStream Source Loader Tab Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SodaStream Source Loader Tab Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the plastic oval and the spring within it.
    7. SodaStream Source Loader Tab Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SodaStream Source Loader Tab Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull the loader tab cover down and away from the rest of the carbonating block.
    8. SodaStream Source Loader Tab Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the three 17.9 mm screws located on the right side.
      • These screws may be difficult to access.
    9. SodaStream Source Loader Tab Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SodaStream Source Loader Tab Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unhook the four clips on the top of the carbonating block and remove the plastic cover.
    10. SodaStream Source Loader Tab Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SodaStream Source Loader Tab Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SodaStream Source Loader Tab Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lift the clips located on both sides with the plastic spudger. Slide the front cover off.
    11. SodaStream Source Loader Tab Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SodaStream Source Loader Tab Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unhook the silver spring arms on both sides of the device by pushing down.
    12. SodaStream Source Loader Tab Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Grip the right and left sides of the device and pull it into two identical halves.
      • Once these two pieces are apart, all remaining internal components will fall out of the device.
    13. SodaStream Source Loader Tab Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SodaStream Source Loader Tab Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SodaStream Source Loader Tab Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Pull the foam pad up and remove it from the front side of the carbonation component.
    14. SodaStream Source Loader Tab Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the six 17.7 mm screws from the underside of the loader tab piece.
    15. SodaStream Source Loader Tab Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SodaStream Source Loader Tab Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SodaStream Source Loader Tab Replacement: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Pull the loader tab out of the nozzle.
    1. SodaStream Source Loader Tab Replacement, Loader Tab: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SodaStream Source Loader Tab Replacement, Loader Tab: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SodaStream Source Loader Tab Replacement, Loader Tab: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Pull the small inner plastic circle out of the large plastic loader tab piece.
crwdns2935229:08crwdne2935229:0
Angela Mossgrove
crwdns2935283:002/20/17crwdne2935283:0
1,219 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G4, Leahy Spring 2017 crwdns2935289:0USF Tampa, Team S1-G4, Leahy Spring 2017crwdne2935289:0
USFT-LEAHY-S17S1G4
crwdns2935297:084crwdne2935297:0
Thank you SO much for this! I was having a lot of trouble with this thing not releasing the bottle, so I disassembled it all and put it back together and now it works a treat! Not sure what was going on but I am so excited. You weren’t kidding at the end about it all falling apart… took ages to work out how it all went back together, but now I understand it and I have a working SodaStream. 5*!
Amanda L - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Do you know where the tiny magnet goes? It fell out on the table as I was disassembling.
cheryl meeks - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I think it has something to do with the microchip for the LED’s. Can’t figure out how else the light would light. I haven’t taken it apart far enough to find the magnet. Hope this helps you.
Paul Bibeau - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
You can see the magnet in step 18, the first picture. Its right below where a screw used to be.
Tom Green - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I placed sodastream on side and removed top half. I could then see where parts needed to be after they “fell out” for reassembly. More pictures of those steps would be helpful. Thank
crwdns2936753:07crwdne2936753:0 52
crwdns2936753:030crwdne2936753:0 254
crwdns2959996:0crwdne2959996:0 30,145
