SodaStream Fountain Jet A200 CO2 Tube Replacement
  1. SodaStream Fountain Jet A200 CO2 Tube Replacement, Removing the front cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SodaStream Fountain Jet A200 CO2 Tube Replacement, Removing the front cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the two prongs at the bottom of the button which releases the bottles (at the front of the machine).
    • Push both prongs down together; pull this part of the machine out towards you.
    unclipping from behind is a heck of a lot easier
    Lake Country POKER - crwdns2934203:0crwdne2934203:0
  2. SodaStream Fountain Jet A200 CO2 Tube Replacement, Removing the back cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SodaStream Fountain Jet A200 CO2 Tube Replacement, Removing the back cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press in the two gray oval shaped buttons found on either side.
    • Gently pull back on the cover until it releases from the device.
    • Release the buttons and pull the back completely off.
  3. SodaStream Fountain Jet A200 CO2 Tube Replacement, Removing the Carbonation button: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SodaStream Fountain Jet A200 CO2 Tube Replacement, Removing the Carbonation button: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place your hand under the carbonation button and pull up and away from you, towards the back of the machine.
    • Warning: be careful not to pull too hard on the carbonation button; there is a spring under this button that can become loose.
  4. SodaStream Fountain Jet A200 CO2 Tube Replacement, Tightening caps on tubes: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SodaStream Fountain Jet A200 CO2 Tube Replacement, Tightening caps on tubes: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Under the carbonation button, at the end of the slim black tube will be a white cap, turn the cap in a counter clock wise motion to remove.
    • Locate the second white cap, on the front of the machine. Reattach both white caps by turning them in a clockwise direction, ensuring they are on tight.
  5. SodaStream Fountain Jet A200 CO2 Tube Replacement, Putting machine back together: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Line up the prongs on the front cover with those on the machine and gently push until in place.
    the middle clip (with the round hole) has to go on the pin
crwdns2935229:08crwdne2935229:0
Katie Fetters
crwdns2935283:009/17/14crwdne2935283:0
815 crwdns2915208:0crwdne2915208:0
University of Kentucky Louisville, Team 1-2, Mathis Fall 2014 crwdns2935289:0University of Kentucky Louisville, Team 1-2, Mathis Fall 2014crwdne2935289:0
LOUISVILLE-MATHIS-F14S1G2
crwdns2947412:09crwdne2947412:0
Where do you find that black tube with the white caps on the internet. My white cap broke and can't find the replacement part.
Craig V - crwdns2934203:0crwdne2934203:0
mine broke too. plastic nut split in half. probably from chill of CO2 expansion.
where to get replacement part?
brockybeek - crwdns2934203:0crwdne2934203:0
I’m trying to find this nut and tube everywhere. any idea where we can purcase it? or the size and pitch of the nuts au tube?
Michel Bastien - crwdns2934203:0crwdne2934203:0
that makes four of us— where’s the tubing available??
jess youngquest - crwdns2934203:0crwdne2934203:0
Sodastream refuses to sell parts. Maybe get a non working one on eBay for parts.
jimmylasvegas - crwdns2934203:0crwdne2934203:0
Giday Katie, nice work ive just carried out your instructions. im a tradie, and im wrapt by your skills demonstrated. easy to read and i didnt break anything. all the best
cheers
shayno
Shayne van der Klei - crwdns2934203:0crwdne2934203:0
SOLUTION:
Took the hose assembly to Ace Hardware. They cut off the ferrule holding the broken nut on. I had them replace both ends with 1/8" brass FIP caps, with 1/8" hole drilled in center. Used new 1/8" ID compression sleeves. It works better than ever, and won't break in the future!
Thomas E Kieffer - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 32
crwdns2936753:030crwdne2936753:0 123
crwdns2942667:0crwdne2942667:0 17,883
