The microphone enables the phone to record sound from the user. The microphone has the ability to pick up sound waves and convert the sound waves into electronic signals.
Turn off the phone to prevent data loss.
Press and slide the battery out to remove it.
Pry the battery out with your thumb or the iFixit opening tool.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove the four rubber inserts from the screw holes using a pair of tweezers.
Remove the four 3.1mm screws in the corners with a Phillips #00 screwdriver.
Separate the front case from the back case.
Remove the metal bumper from the front case’s perimeter.
Pry the volume slider button out with tweezers.
Separate the circuit board from the inside of the back case by prying between them with the opening tool.
The last picture is a view of the back of the circuit board.
Locate the microphone on the back of the circuit board.
Desolder the microphone from the circuit board using the soldering iron.
