Snapfon ez One Charging Port Replacement
  1. Snapfon ez One Charging Port Replacement, Remove the battery cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn off the phone to prevent data loss.
    • Press and slide the battery out to remove it.
    • Picture rights belong to Snapfon®. Picture is used for educational purposes only. No copyright infringement intended.
  2. Snapfon ez One Charging Port Replacement, Remove the battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the battery out with your thumb or the iFixit opening tool.
    • Make sure to properly dispose of the old battery at a recycling center.
  3. Snapfon ez One Charging Port Replacement, Removing the plastic inserts: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Snapfon ez One Charging Port Replacement, Removing the plastic inserts: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four rubber inserts from the screw holes using a pair of tweezers.
  4. Snapfon ez One Charging Port Replacement, Remove the shield screws: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Snapfon ez One Charging Port Replacement, Remove the shield screws: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Snapfon ez One Charging Port Replacement, Remove the shield screws: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 3.1mm screws in the corners with a Phillips #00 screwdriver.
  5. Snapfon ez One Charging Port Replacement, Separate the case: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Snapfon ez One Charging Port Replacement, Separate the case: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Snapfon ez One Charging Port Replacement, Separate the case: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Separate the front case from the back case.
    • Remove the metal bumper from the front case’s perimeter.
  6. Snapfon ez One Charging Port Replacement, Remove the volume slider: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the volume slider button out with tweezers.
    • The volume slider button may fall out during the separation of the front and back cases. This is OK.
  7. Snapfon ez One Charging Port Replacement, Remove the motherboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Snapfon ez One Charging Port Replacement, Remove the motherboard: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Snapfon ez One Charging Port Replacement, Remove the motherboard: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Separate the circuit board from the inside of the back case by prying between them with the opening tool.
    • The last picture is a view of the back of the circuit board.
  8. Snapfon ez One Charging Port Replacement, Charging Port: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Snapfon ez One Charging Port Replacement, Charging Port: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Snapfon ez One Charging Port Replacement, Charging Port: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers to remove the charging port located inside the back cover of the phone.
    • A spudger may be needed to apply pressure with the use of the tweezers for easier removal.
Insert new charging port, and to reassemble your device, follow these instructions in reverse order.
John Bender
crwdns2935283:003/26/14crwdne2935283:0
818 crwdns2915208:0crwdne2915208:0
Clemson, Team 6-5, Benson Spring 2014 crwdns2935289:0Clemson, Team 6-5, Benson Spring 2014crwdne2935289:0
CLEM-BENSON-S14S6G5
crwdns2942667:0crwdne2942667:0 387
