Snapfōn ezONE LCD Screen Replacement
  1. Snapfōn ezONE LCD Screen Replacement, Remove the battery cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn off the phone to prevent data loss.
    • Press and slide the battery out to remove it.
    • Picture rights belong to Snapfon®. Picture is used for educational purposes only. No copyright infringement intended.
  2. Snapfōn ezONE LCD Screen Replacement, Remove the battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the battery out with your thumb or the iFixit opening tool.
    • Make sure to properly dispose of the old battery at a recycling center.
  3. Snapfōn ezONE LCD Screen Replacement, Removing the plastic inserts: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Snapfōn ezONE LCD Screen Replacement, Removing the plastic inserts: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four rubber inserts from the screw holes using a pair of tweezers.
  4. Snapfōn ezONE LCD Screen Replacement, Remove the shield screws: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Snapfōn ezONE LCD Screen Replacement, Remove the shield screws: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Snapfōn ezONE LCD Screen Replacement, Remove the shield screws: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 3.1mm screws in the corners with a Phillips #00 screwdriver.
  5. Snapfōn ezONE LCD Screen Replacement, Separate the case: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Snapfōn ezONE LCD Screen Replacement, Separate the case: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Snapfōn ezONE LCD Screen Replacement, Separate the case: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Separate the front case from the back case.
    • Remove the metal bumper from the front case’s perimeter.
  6. Snapfōn ezONE LCD Screen Replacement, Remove the volume slider: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the volume slider button out with tweezers.
    • The volume slider button may fall out during the separation of the front and back cases. This is OK.
  7. Snapfōn ezONE LCD Screen Replacement, Remove the motherboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Snapfōn ezONE LCD Screen Replacement, Remove the motherboard: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Snapfōn ezONE LCD Screen Replacement, Remove the motherboard: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Separate the circuit board from the inside of the back case by prying between them with the opening tool.
    • The last picture is a view of the back of the circuit board.
  8. Snapfōn ezONE LCD Screen Replacement, Pry the screen back: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Snapfōn ezONE LCD Screen Replacement, Pry the screen back: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Snapfōn ezONE LCD Screen Replacement, Pry the screen back: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry the LCD screen off of the circuit board using the opening tool. The screen is connected to the motherboard with light adhesive, which is easy to remove.
    • The LCD screen will still be connected to the circuit board by a ribbon cable.
  9. Snapfōn ezONE LCD Screen Replacement, Disconnect the display: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a soldering iron to melt away the connection between the ribbon cable and circuit board.
    • Be careful! High temperatures from the soldering iron may result in injury.
    • Only make contact with the solder connection so that none of the phone’s components are damaged by the heat.
  10. Snapfōn ezONE LCD Screen Replacement, Remove the display: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Snapfōn ezONE LCD Screen Replacement, Remove the display: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once you heat the solder connection, lightly tug the ribbon cable free. The LCD screen will be completely removed from the device.
To reassemble your device with a new LCD screen, follow these instructions in reverse order.
Note: you will need to use the soldering iron again to attach the new LCD screen ribbon to the circuit board.
John Bender
crwdns2935283:003/26/14crwdne2935283:0
818 crwdns2915208:0crwdne2915208:0
Clemson, Team 6-5, Benson Spring 2014 crwdns2935289:0Clemson, Team 6-5, Benson Spring 2014crwdne2935289:0
CLEM-BENSON-S14S6G5
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 475
