If your USB SmartDevil Snow Mountain Humidifier suddenly gives off a bad smell or stops working, it’s time to change the filter.
Filter for USB humidifier should be changed every 2-3 months. Not only this maintenance helps users avoid respiratory illness, it can also prolong the device’s lifespan by improving mist quality and prevent mold from blocking the outlet.
Follow this guide to replace the filter for SmartDevil Snow Mountain Humidifier (model GXZ-J623). If your USB Humidifier uses a cotton filter, this guide can also be applied to yours.
Unscrew the tank cap counterclockwise to open the humidifier.
Slightly twist the filter compartment counterclockwise until it clicks.
Pull the filter compartment out.
Take the cotton filter and the spring metal out of the compartment.
Take a new cotton filter. Cut the new filter equal to the length of the compartment.
Soak the new cotton filter in mineral water or tap water for 3 to 5 minutes.
Place the metal spring at the bottom of the compartment.
Insert the new cotton filter into the compartment, put the new filter on top of the metal spring.
Plug the compartment to the tank cap. Slightly twist the compartment clockwise to lock it.
Use a cotton swab to clean dust and mold on the mist outlet.
Fill the tank with water and close the tank cap.
crwdns2935229:05crwdne2935229:0
crwdns2944067:08crwdne2944067:0
do all smart devil humidifiers have springs i did not see the in mine
Where do I get a replacement cotton filter?
Boao 40 Pieces Humidifier Sticks Cotton Filter Refill Travel Humidifier Sticks Car Humidifier Replacement Parts for Mini Portable Personal USB Powered Humidifiers in Office Bedroom (4 Inch) https://a.co/d/0MpspKK
Jmat -
I have 3 of these, 1 pumps out the perfect amount of humidity and last about 20 hours but 2 of them pump out waaay too much! They empty in 8 hours. Is there a way to slow them down? The slower one is absolutely perfect I would like them all the same. Help please
Where do I get the spring, mine didnt have one, can I order one
