Sliding Glass Door Rollers Replacement
  1. Sliding Glass Door Rollers Replacement, Door Rollers: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Find the screw on the bottom of the door. Adjust the rollers to the highest setting to lift the rollers off track.
    • The adjustment screw is normally at the bottom.
  2. Sliding Glass Door Rollers Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the door off the track by grabbing both sides of the door and shimmy it out until it is loose.
    • This step may require two people.
  3. Sliding Glass Door Rollers Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the doors on a steady table or surface. On the bottom of the doors near where the rollers are, there are two screws. Remove the top one with the Phillips #3 screwdriver to release the rollers.
  4. Sliding Glass Door Rollers Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now that the rollers are loose, slide them off of the door.
  5. Sliding Glass Door Rollers Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Install the new door rollers by sliding them into place where the old ones were removed.
  6. Sliding Glass Door Rollers Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #3, adjust the new rollers so they are at their highest point inside the door frame to easily put door back on tracks.
  7. Sliding Glass Door Rollers Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Put the doors back on the tracks by first sliding the top part of the doors into place. After that slide in the lower part of the door.
    • Make sure your doors are on the track or they will not move properly.
  8. Sliding Glass Door Rollers Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Finally, readjust the rollers to the proper height where the doors roll smoothly. You may have to guess and check until the doors operate smoothly. To do this use a Phillips #3 screwdriver to tighten and loosen the screw until the desired height is found.
Sliding glass door rollers go through wear and tear, which can make the doors difficult to use. After completing this guide your doors should be rocking and rolling like new!
Britni Coder
crwdns2935283:010/13/20crwdne2935283:0
207 crwdns2915208:0crwdne2915208:0
Linn Benton Community College, Team S1-G5, Johnson Fall 2020 crwdns2935289:0Linn Benton Community College, Team S1-G5, Johnson Fall 2020crwdne2935289:0
LBCC-JOHNSON-F20S1G5
Step 1: Find the screw on the bottom of the door. Adjust the rollers to the highest setting to lift the rollers off track.
Probably not. The rollers are adjusted to the LOWEST setting. That gives the most clearance to lift the door off the track. Set it to 'highest' and the rollers will likely hang up on the track when you try to lift the door OFF the track.
What is this point of view based on? Having done it half a dozen times.
canyncarvr - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 52
crwdns2942667:0crwdne2942667:0 6,244
