By following this guide one is able to access the speakers of the Skytex Skypad Alpha 2 tablet in two steps. These steps include removing soldered connections and removing the speaker itself.
Remove the (4) 3.5mm screws using a phillips #000 screwdriver.
Use the plastic opening tool to work your way around the tablet, releasing the back case from the tabs.
Release the back case from the rest of the tablet with your hand.
Remove the soldered connections to separate the speaker wires from the motherboard.
Remove the speaker from the tablet using the plastic opening tool.
