Skytex Skypad Alpha 2 Speaker Replacement
  1. Skytex Skypad Alpha 2 Speaker Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power off the tablet.
    • Unplug the tablet from the power source if it is connected.
  2. Skytex Skypad Alpha 2 Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Skytex Skypad Alpha 2 Speaker Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the (4) 3.5mm screws using a phillips #000 screwdriver.
  3. Skytex Skypad Alpha 2 Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to work your way around the tablet, releasing the back case from the tabs.
  4. Skytex Skypad Alpha 2 Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Release the back case from the rest of the tablet with your hand.
    • Do not pry the case too hard; doing so can damage the tablet.
  5. Skytex Skypad Alpha 2 Speaker Replacement, Speaker: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the soldered connections to separate the speaker wires from the motherboard.
    • Remove all black and yellow tape, if necessary, on the motherboard.
    • Following the red and black wires, coming out of the speaker, to their respective connections on the motherboard will indicate where to solder.
    • Follow the link below for further soldering information: How To Solder and Desolder Connections.
    • Soldering irons require a larger amount of heat; use caution when performing this step. Excessive heat can damage parts of your device; do not leave the soldering iron on connections for extended periods of time.
  6. Skytex Skypad Alpha 2 Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the speaker from the tablet using the plastic opening tool.
    • This will not require much force, prying from the flat side of the speaker will do the job.
Rebecca Ramirez
crwdns2935283:009/23/15crwdne2935283:0
481 crwdns2915208:0crwdne2915208:0
Baylor, Team 6-5, Williams Fall 2015 crwdns2935289:0Baylor, Team 6-5, Williams Fall 2015crwdne2935289:0
BU-WILLIAMS-F15S6G5
crwdns2942667:0crwdne2942667:0 177
