Skytex SP728 Screen Replacement
  1. Skytex SP728 Screen Replacement, Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the device is powered off
    • Rotate the device so the ports and screws face you
  2. Skytex SP728 Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a small phillips screwdriver, unscrew both end screws
  3. Skytex SP728 Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
  4. Skytex SP728 Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the case has been loosened, pry the backing off gently with your hands.
    • Make sure to remove the case gently as extra force can break the clasps or the case itself.
  5. Skytex SP728 Screen Replacement, Screen: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Skytex SP728 Screen Replacement, Screen: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Skytex SP728 Screen Replacement, Screen: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Follow the Case Replacement to separate the tablet from its backing
    • Using a small Phillips screw driver, unscrew all screws connecting circuit board to device
    • Remove all tape connecting battery and circuit board to front case
    • Detach all connector strips from the circuit board
  6. Skytex SP728 Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Skytex SP728 Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic opening tool, begin separating the front screen from the display
  7. Skytex SP728 Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once screen has been separated, use tweezers to remove front camera
To reassemble your device with a new screen, follow these instructions in reverse order.
Michelle Strickland
crwdns2935283:001/21/15crwdne2935283:0
304 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 5-1, Brown Winter 2015 crwdns2935289:0USF Tampa, Team 5-1, Brown Winter 2015crwdne2935289:0
USFT-BROWN-W15S5G1
crwdns2935297:011crwdne2935297:0
crwdns2942667:0crwdne2942667:0 271
