Sky 6.0Q Top Motherboard Replacement
  1. Sky 6.0Q Top Motherboard Replacement, Top Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the #00 Phillips screwdriver to remove the two 3 mm screws at the bottom of the backplate.
    • Pry off the back plate with the spudger.
  2. Sky 6.0Q Top Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing back panel, remove all ten 3mm screws with the #00 Phillips screwdriver from the black plastic casing so it can be removed.
  3. Sky 6.0Q Top Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sky 6.0Q Top Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the plastic opening tool to help pry up the plastic backing.
    • Once loose, remove the plastic backing to expose underlying electronic components.
  4. Sky 6.0Q Top Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the spudger disconnect the gold cord extending from the battery to the top electronic board.
  5. Sky 6.0Q Top Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sky 6.0Q Top Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sky 6.0Q Top Motherboard Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the nylon spudger to help pry up the three top motherboard attachments.
    • See all three pictures for three attachment locations.
    • To reattach top motherboard connections gently press piece back in place.
  6. Sky 6.0Q Top Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the #00 Phillips screwdriver to remove the three 3 mm screws attaching the top motherboard.
  7. Sky 6.0Q Top Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the screws are removed, gently lift the top motherboard and replace.
Monica Difato
crwdns2935283:011/06/18crwdne2935283:0
459 crwdns2915208:0crwdne2915208:0
IUPUI, Team S1-G3, Hovde Fall 2018 crwdns2935289:0IUPUI, Team S1-G3, Hovde Fall 2018crwdne2935289:0
IUPUI-HOVDE-F18S1G3
crwdns2942667:0crwdne2942667:0 597
