Use this guide to replace worn-out, ripped, or old earpads for your Skullcandy Hesh ANC headphones.
Before using this guide, make sure you have a replacement earpad that is compatible with the headphone model (Hesh ANC).
This guide is completely safe but will require you to come into contact with the raw speakers of the headphones, which should be shockproof as long as no contact with water is made.
It is important you replace your earpads once they are old; it makes your headphones more comfortable, prevents any skin irritation you might get from worn-out leather, and improves the listening experience by a mile. Read more on the importance and maintenance of earpads Here.
Locate the seam at the top or bottom of the ear pad.
Pull the damaged earpad gently, starting from the seam located in Step 1.
Pull until you can see the seam of the earpad start to come off the headphones.
Once the ear pad is completely removed, softly clean the surface of the exposed headphone speakers and the area surrounding it with a clean cloth.
Grab your replacement earpads and again, locate the seam.
Starting from the top of the headphones, slowly and gently align the seam of the earpad into the slot allocated for it.
Use a finger to keep the replacement earpad in place once inserted.
With the top held in place, slowly work your way around the earpad, aligning it around the headphone until the seam isn't visible anymore and the earpad is firmly in place.
Use your fingers to softly press around the edges of the earpad to ensure it has been completely attached.
