Skullcandy Air Raid Speakers Replacement
  1. Skullcandy Air Raid Speakers Replacement, Rubber Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Starting with the corners, gently pull the rubber cover off of the device.
  2. Skullcandy Air Raid Speakers Replacement, Handle: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the T-6 hexagonal screwdriver, unscrew the four 10mm #6 hex screws on the right side of the device.
    • Remove the handle from the device.
  3. Skullcandy Air Raid Speakers Replacement, Front Plate: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the two screws on the left side of the device using the phillips #00 screwdriver.
    • One 5mm Phillips screw.
    • One 8mm Phillips screw.
  4. Skullcandy Air Raid Speakers Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the sides of the front plate outwards from the device.
    • Pull up on the front plate to remove it from the device.
  5. Skullcandy Air Raid Speakers Replacement, Speakers: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a #000 Phillips Screwdriver, unscrew the four 0.8 cm Philips screws from each corner of the speaker you are replacing (eight 0.8 Philips screws total).
  6. Skullcandy Air Raid Speakers Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the plastic opening tool, pry around edges of speaker to loosen glue contact with front plate.
    • If you are unable to loosen glue contact using the plastic opening tool, use a heat gun to assist in removal.
    Please confirm the size of it's speakers.
    Alberic Sungahid - crwdns2934203:0crwdne2934203:0
  7. Skullcandy Air Raid Speakers Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the speaker out of the device.
    • Be aware of the connection with the ribbon cable.
    • For reassembly, ensure proper orientation of the cable plug.
  8. Skullcandy Air Raid Speakers Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Firmly pull on the end of the ribbon cable to disconnect the speaker from the motherboard.
  9. Skullcandy Air Raid Speakers Replacement, Desolder Wires: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder the black and red wires from the speaker.
    • The red wire is for the left speaker and the black is for the right speaker.
Kristin
crwdns2935283:001/13/15crwdne2935283:0
495 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 1-3, Carnegie Winter 2015 crwdns2935289:0Eastern Washington University, Team 1-3, Carnegie Winter 2015crwdne2935289:0
EWU-CARNEGIE-W15S1G3
Where can I buy the replacement speaker?
Luis Polino - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 1,660
