Starting with the corners, gently pull the rubber cover off of the device.
Using the T-6 hexagonal screwdriver, unscrew the four 10mm #6 hex screws on the right side of the device.
Remove the handle from the device.
Unscrew the two screws on the left side of the device using the phillips #00 screwdriver.
One 5mm Phillips screw.
One 8mm Phillips screw.
Gently pull the sides of the front plate outwards from the device.
Pull up on the front plate to remove it from the device.
