Skullcandy Air Raid Battery Replacement
  1. Skullcandy Air Raid Battery Replacement, Rubber Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Starting with the corners, gently pull the rubber cover off of the device.
  2. Skullcandy Air Raid Battery Replacement, Handle: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the T-6 hexagonal screwdriver, unscrew the four 10mm #6 hex screws on the right side of the device.
    • Remove the handle from the device.
  3. Skullcandy Air Raid Battery Replacement, Front Plate: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the two screws on the left side of the device using the phillips #00 screwdriver.
    • One 5mm Phillips screw.
    • One 8mm Phillips screw.
  4. Skullcandy Air Raid Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the sides of the front plate outwards from the device.
    • Pull up on the front plate to remove it from the device.
  5. Skullcandy Air Raid Battery Replacement, Speakers: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a #000 Philips Screwdriver, unscrew the four 8 mm Philips screws from each corner of both speakers (eight 8 mm Philips screws total).
  6. Skullcandy Air Raid Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the plastic opening tool, pry around edges of the speaker to loosen glue contact with front plate.
    • If you are unable to loosen glue contact using the plastic opening tool, use a heat gun to assist in removal.
  7. Skullcandy Air Raid Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the speaker out of the device.
    • Be aware of the connection with the ribbon cable.
    • For reassembly, ensure proper orientation of the cable plug.
  8. Skullcandy Air Raid Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Firmly pull on the end of ribbon cable to disconnect the speaker from the motherboard.
  9. Skullcandy Air Raid Battery Replacement, Control Buttons: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #00 Precision Screwdriver, unscrew two 6 mm screws from the middle of the panel, above and below volume buttons.
  10. Skullcandy Air Raid Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the button panel.
  11. Skullcandy Air Raid Battery Replacement, Button Motherboard: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #00 Precision Screwdriver, unscrew two 6 mm screws from the button motherboard.
  12. Skullcandy Air Raid Battery Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a plastic opening tool, pry the button motherboard to detach it from the device.
    • The button motherboard is connected to a ribbon cable inside the device.
  13. Skullcandy Air Raid Battery Replacement, Ribbon Cable: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the black ribbon cord attachment away from the motherboard.
    • Pull on the cable until it releases from the back of the motherboard.
    • The black attachment is part of the connector, not the blue ribbon cable, so it will not disconnect from the motherboard.
  14. Skullcandy Air Raid Battery Replacement, Back panel: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Skullcandy Air Raid Battery Replacement, Back panel: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #00 Precision Screwdriver, unscrew two 8 mm screws.
    • Lift off the back panel.
    How do you pull off the back panel? Those two parts are really stuck to each other.
    Brandon De La Rosa - crwdns2934203:0crwdne2934203:0
    There's four additional screws in the corners! How did you miss that?
    David Lassabe - crwdns2934203:0crwdne2934203:0
  15. Skullcandy Air Raid Battery Replacement, Battery: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull on the ribbon cable that connects the battery to the motherboard until the connector releases.
  16. Skullcandy Air Raid Battery Replacement, Removing Battery: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull battery straight out until it is completely out of device.
    • If you are unable to loosen glue contact, use a heat gun to assist in removal.
    Battery: 2000 mAh - 3.7v - 7.4Wh. Part number (printed on battery) AEC553450-2P.
    Andy Padilla - crwdns2934203:0crwdne2934203:0
    Can you please tell me where the white wire in from the battery terminal goes please .. I have a red a black and a white wire and the white wire is not connected anywhere .. i have just bought 3 of these skull air raids as faulty and would like to repair them for my kids .. many thanks
    Martin Cook - crwdns2934203:0crwdne2934203:0
    Great instructions. Very helpful. But is there any place to find this battery?
    shoretorun - crwdns2934203:0crwdne2934203:0
  17. Skullcandy Air Raid Battery Replacement, Battery selection: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The battery has 3 wires - the middle white wire is to prevent overheating so look for a 3 wire replacement battery.
  18. Skullcandy Air Raid Battery Replacement, Replacement battery adaptation: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Skullcandy Air Raid Battery Replacement, Replacement battery adaptation: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If you aren't able to source an official replacement battery, follow the next two steps for tips on alternate battery replacements.
    • This is actually 2 × 1000mAh 3.7V batteries. The total is 2000mAhm, or 7.4Wh. The battery compartment is the limiting factor, so a replacement should be 10mm deep, 54mm long and 34mm wide.
  19. Skullcandy Air Raid Battery Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Skullcandy Air Raid Battery Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Skullcandy Air Raid Battery Replacement: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If you have a replacement battery picked out, you can remove and reorder the wires to fit the original connector. Pictured is an example replacement. This battery requires cutting and soldering the 3 leads from the old battery.
Kristin
crwdns2935283:001/13/15crwdne2935283:0
495 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 1-3, Carnegie Winter 2015 crwdns2935289:0Eastern Washington University, Team 1-3, Carnegie Winter 2015crwdne2935289:0
EWU-CARNEGIE-W15S1G3
crwdns2947412:07crwdne2947412:0
Hi, my name is Alex, and i have the same problem. The battery does not work anymore, but i don't know where can i find a replacement, and what is the its name. Or mabe something similar? I live in Romania so i need mabe an international online store to buy it. Thank you! My email is stanciualex_e@ yahoo.com
Alex - crwdns2934203:0crwdne2934203:0
What is the type of battery?
grigoriev85 - crwdns2934203:0crwdne2934203:0
I have the same issue. I want to acquire a replacement.
It is a rechargeable battery Model AEC553450-2P / 2000mA 3.7V 7.4Wh.
It there anybody out there who could help us I will appreciate it very much
Fernando Morales - crwdns2934203:0crwdne2934203:0
I also need a battery, have you found one?
Noah Larsen -
Noah Larsen - crwdns2934203:0crwdne2934203:0
ive been trying to fix this sme exact speaker and it is unessary to remove the speaker screews, so id recoment leaving those in place
Octavio Morales Guerrero - crwdns2934203:0crwdne2934203:0
It seems like the 2 batteries from the original pack share a ground, I purchased a single 2 wire 1000mAh Li-ion battery without realizing. I'm going to purchase another from digikey and attempt to put them together
Cole Miller - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 41
crwdns2942667:0crwdne2942667:0 9,843
