SkullCandy INK'D 2 Audio Jack Replacement
  1. SkullCandy INK'D 2 Audio Jack Replacement, Audio Jack: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SkullCandy INK'D 2 Audio Jack Replacement, Audio Jack: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use wire cutters to remove the audio jack.
    • Use wire cutters to remove approximately 1/2 inch of insulation of the wire and separate the four wires inside of it.
    • Red wire is the right speaker '+' terminal.
    • Green wire is the left speaker '+' terminal.
    • Golden wire is the ground terminal.
    • Purple wire is the microphone terminal.
  2. SkullCandy INK'D 2 Audio Jack Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take the replacement connector and separate the wires on it.
    • Red wire is the right earphone.
    • Green wire is the left earphone.
    • Blue wire is the ground terminal.
    • Gold wire is the microphone.
  3. SkullCandy INK'D 2 Audio Jack Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Heat Shrink Tubing Assortment
    $7.99
    • Put shrink tubing on either one of the wires.
    • For each wire color, put the headphone wire and the replacement wire into clamps. Weave them together using fingers.
    • Review the soldering guide before initiating Step 4.
  4. SkullCandy INK'D 2 Audio Jack Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use soldering equipment to solder together two wires.
    • Repeat this step for each of the four wire colors.
    • Always wear safety glasses when soldering.
  5. SkullCandy INK'D 2 Audio Jack Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Digital Multimeter
    $19.99
    • Using Digital Multimeter in the "Continuity" mode, place two probes on the soldered wires of the same color. You will hear audio signal indicating that there is a connection.
    • Repeat this for each of the wire colors.
    • If there is no Multimeter signal, you will need to resolder the wires and to make sure that wires of different colors are completely separated.
  6. SkullCandy INK'D 2 Audio Jack Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SkullCandy INK'D 2 Audio Jack Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SkullCandy INK'D 2 Audio Jack Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Heat Gun
    $24.99
    • After all wires are soldered, cover them with shrink tubing.
    • Use the heat gun to shrink the tubing and fit it tightly around the wires.
    • Gently apply heat in order to shape the tubing around the soldered wires.
Repeat the procedure if you need to install a new audio jack.
Maksim Bondaruk
crwdns2935283:010/16/17crwdne2935283:0
119 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S4-G1, Livingston Fall 2017 crwdns2935289:0Cal Poly, Team S4-G1, Livingston Fall 2017crwdne2935289:0
CPSU-LIVINGSTON-F17S4G1
crwdns2935297:025crwdne2935297:0
alguien sabe como conectar los 4 cables a un parlante
Brandon Melendez Robles - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 13
crwdns2936753:07crwdne2936753:0 82
crwdns2936753:030crwdne2936753:0 333
crwdns2942667:0crwdne2942667:0 19,264
