Grip the drill. Locate the red locking switch on the back of the battery. Hold the switch down.
While holding down the red locking switch, slide the battery towards the back of the drill until the battery is fully removed from the drill.
Grip cordless drill firmly with left hand. Grip the cordless drill handle firmly with the right hand. Rotate the handle counterclockwise in order to remove the handle from the drill.
Hold drill upright with one hand and slide the gauge backwards to remove it with the other.
The chuck sleeve is held on by a 20mm Phillips #2 screw in the center.This screw is reverse threaded. Insert a Phillips #2 screwdriver and rotate it clockwise to loosen and remove it.
The threaded hole the screw was in is in the shape of a 6-point star. Insert a T40 Torx Key and rotate it clockwise to loosen and remove the chuck sleeve.
The adjustable clutch is held on by 2 20mm T10 Torx screws. Insert a T10 Torx screwdriver and rotate it counterclockwise to loosen and remove each screw.
Firmly grip the outside of the adjustable clutch and pull it off.
Locate 4 screws on front of the drill. Remove using Torx T10
Remove front casing piece.
Locate 4 screws on back of the drill.Remove using Torx T10.
Remove back casing piece.
Locate 4 screws on side of the drill. Remove using Torx T10
After all screws have been removed both side casings can be taken apart.
Disconnect all wiring on top of trigger coming from motor and board.
Reconnect all wiring to your new trigger
