Skil X-Drive 18V Cordless Drill Model No. 2887 Battery Replacement
  1. Skil X-Drive 18V Cordless Drill Model No. 2887 Battery Replacement, Un-clip Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grip the drill. Locate the red locking switch on the back of the battery. Hold the switch down.
  2. Skil X-Drive 18V Cordless Drill Model No. 2887 Battery Replacement, Remove Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Skil X-Drive 18V Cordless Drill Model No. 2887 Battery Replacement, Remove Battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Skil X-Drive 18V Cordless Drill Model No. 2887 Battery Replacement, Remove Battery: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While holding down the red locking switch, slide the battery towards the back of the drill until the battery is fully removed from the drill.
Sean
crwdns2935283:009/23/14crwdne2935283:0
282 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 2-3, Blackwell Fall 2014 crwdns2935289:0USF Tampa, Team 2-3, Blackwell Fall 2014crwdne2935289:0
USFT-BLACKWELL-F14S2G3
crwdns2947412:05crwdne2947412:0
my battery is stuck in the drill any ideas
yonko99 - crwdns2934203:0crwdne2934203:0
My battery is also stuck. I see no replies. What now?
Bobby Verdier - crwdns2934203:0crwdne2934203:0
Thank you, it really was easy !!!!!
Betty - crwdns2934203:0crwdne2934203:0
My battery is stuck too. I read on another forum to use a screwdriver and hammer.
I’m a girl, so don’t take my advice, but wondering if you could you spray it with WD-40 to loosen it up?
Amy Dionne - crwdns2934203:0crwdne2934203:0
Have you been able to get it out? On mine the button was hard to get all the way down. I used both thumbs and was eventually able to get it down far enough to get it off. I bumped it on my leg to help loosen it. If you use a hammer I would suggest using a rubber mallet so you don’t damage the battery or the drill.
Once it’s off clean up the slides real good, spray some WD40 on them, then wipe off with a rag. That should help prevent it from getting stuck again. I would spray a little WD40 on the button and work it back and forth as well.
Hope this helps
Brian Harrod -
crwdns2936753:030crwdne2936753:0 69
crwdns2942667:0crwdne2942667:0 6,864
