Skil 88 Motor Housing Replacement
  1. Skil 88 Motor Housing Replacement, Disassembling Skil 88 Front Housing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the front of the drill, remove the three 2" flathead screws connecting the front housing to the rear housing.
  2. Skil 88 Motor Housing Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Skil 88 Motor Housing Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the front housing apart from the rear.
    • The motor and gears might fall out when you are pulling it apart.
  3. Skil 88 Motor Housing Replacement, Trigger Housing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Skil 88 Motor Housing Replacement, Trigger Housing: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the socket wrench to remove the 0.5" length screw from the bottom of the handle.
  4. Skil 88 Motor Housing Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Skil 88 Motor Housing Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Skil 88 Motor Housing Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Separate the cord from the handle.
  5. Skil 88 Motor Housing Replacement, Motor Housing: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Skil 88 Motor Housing Replacement, Motor Housing: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the inner divider.
  6. Skil 88 Motor Housing Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 1" flathead screws located at the top and bottom of the motor housing.
  7. Skil 88 Motor Housing Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Skil 88 Motor Housing Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the motor housing out.
    • The wires from the trigger housing should follow the motor housing.
  8. Skil 88 Motor Housing Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Skil 88 Motor Housing Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After you have placed the motor housing back into the drill during reassembly, thread the wires down to the handle using tweezers.
    • Plug the forked wire into the socket at the back of the motor housing using tweezers.
To continue reassembly, simply follow the guide backwards starting at step 2.
Matt
crwdns2935283:010/10/10crwdne2935283:0
365 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 5-17, Maness Fall 2010 crwdns2935289:0Cal Poly, Team 5-17, Maness Fall 2010crwdne2935289:0
CPSU-MANESS-F10S5G17
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 2,941
