Is your skateboard veering off in the wrong direction or are you not going in a straight path? Then it’s time to replace the hanger of your skateboard. This guide will teach you how to disassemble & replace a skateboard hanger if it's damaged or broken.
Using the T-tool, unscrew the nut securing the wheel and remove it, setting it and the wheel aside.
Using the T-Tool, unscrew the Kingpin nut, washer and top bushing so that the hanger itself can be taken off.
Pull straight up to remove the hanger. Remove the lower bushing and the lower cup washer just to check on the riser.
To reassemble, take the lower cup washer, then the lower bushing and put it on the kingpin. Next, set the replacement hanger on top of the lower bushing.
After the hanger is added, put the the top bushing, the top cup washer and then the Kingpin nut back.
After the kingpin nut is secured, take your T-Tool and add the wheels back onto and secure them in place.
