The LED screen is attached to the motherboard inside the casing. This guide will show how to detach the screen from the motherboard for replacement.
Take the iFixit opening tool and place it between the crevice as shown.
Apply pressure to the iFixit opening tool, pushing down until the the plastic casing pops off.
Use the Phillips PH00 to remove the three marked screws.
Once the screws have been removed, the motherboard is free to come out.
Remove the plastic case in front of the socket using the spudger.
Hold the screen and gently pull in the direction of the cable to separate screen from the socket.
