crwdns2959928:0crwdne2959928:0 ↓Buttons might tear and get worn out so it is important to replace the buttons.
Wedge a plastic opening tool in between the case.
Starting with the bottom left corner, press down on the plastic opening tool to unhook the latches on the inside of the device.
Once unclipped, separate the back casing from the device.
Remove the three 5mm JIS #00 screws from the motherboard.
Unlatch the two clips that hold the motherboard in place.
Lift the motherboard up and out of the frame.
Holding the front casing in your hand, push the button panels out of the casing.
