This is the start of any work done on the Sirius S50-EX1. It has a frustrating quantity of adhesive to keep the plate down, so care must be taken to ensure that the aging plastic does not snap when being pulled on.
Pry the speaker covers up gently from their sides by pulling up on the four corner posts that hold the cover in place.
Remove the eight 11 mm screws from the front plate using a Phillips #1 screwdriver.
Turn the device so its back is facing you.
Remove the two 11 mm screws using a Phillips #1 screwdriver.
Separate the stand from the device.
Remove the two 9 mm screws with a Phillips #1 screwdriver.
Turn the device so that its front is visible.
Remove the channel dial by pulling up on the dial firmly.
Remove the S50 by pulling it up and off of its connecting posts.
Use an iFixit opening tool to pull up both sides of the speaker plate. They should come up easily. Pull firmly on the center to break the adhesive.
Remove the three bundled-cable wires.
Remove the ribbon cable connector.
Remove the power connector cable.
