SimpliSafe Original Base Station Cellular Chip Module Replacement
  1. SimpliSafe Original Base Station Cellular Chip Module Replacement, Prepare your Base Station: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure you perform the work on a flat well-lit surface.
  2. SimpliSafe Original Base Station Cellular Chip Module Replacement, Turn the Base Station on the side and twist to remove the top cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SimpliSafe Original Base Station Cellular Chip Module Replacement, Turn the Base Station on the side and twist to remove the top cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grasp the base of the Base Station with one hand and the upper part near the center while slowly twisting counter clockwise and up.
  3. SimpliSafe Original Base Station Cellular Chip Module Replacement, Fully remove the top cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Set the top cover somewhere to the side and in a safe area—you won't need this until reassembly.
  4. SimpliSafe Original Base Station Cellular Chip Module Replacement, Remove the cellular chip module: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SimpliSafe Original Base Station Cellular Chip Module Replacement, Remove the cellular chip module: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SimpliSafe Original Base Station Cellular Chip Module Replacement, Remove the cellular chip module: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the Base Station on its side to achieve a better angle for the disassembly.
    • Use a Phillips #1 screwdriver bit to remove 3 screws securing the chip module to the rest of the base station.
    • After you remove the screws, you'll need to disconnect the cable connecting the two chip boards that are secured with an FPC connector.
    • Use your fingers to grip the two edges of the cable and firmly pull up while holding the board down. Do so carefully so as not to remove the soldered connector from the board.
  5. SimpliSafe Original Base Station Cellular Chip Module Replacement, Remove the FPC Connector Cable: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the connector link cable between the two boards after disconnecting the cellular chip board.
    • Use the same method as before, gripping just the edges of the connector and pulling up.
  6. SimpliSafe Original Base Station Cellular Chip Module Replacement, Install the new chip module: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Resecure the FPC Connecting cable to the board and to the new chip module.
    • Use the three Phillips #1 screws from the earlier step and resecure the module to the base station.
  7. SimpliSafe Original Base Station Cellular Chip Module Replacement, Reassemble your Base Station: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reattach the Base Station cover.
    • SimpliSafe provides you with a prepaid label and ESD-safe bubble wrap to ship back the old module for recycling.
Matt Zieminski
crwdns2935283:002/23/14crwdne2935283:0
175 crwdns2915208:0crwdne2915208:0
iPhone Repairs by Matt crwdns2935289:0iPhone Repairs by Mattcrwdne2935289:0
Business
crwdns2942667:0crwdne2942667:0 2,854
